replace fog light bulb?, a little bit confused |
May 31, 2008 - 1:09 AM |
Enthusiast Joined Apr 18, '08 From Oakland, bay area, California Currently Offline Reputation: 1 (100%) |
im in the process of installing my foglights on my 95 celica and i was wonderingg... how do u replace the foglight bulbs? i cant find it on the forums so im assuming im the only one having this problem. i know its kinda stupid, but for some reason i cant find out how!? after i twist it and move the black grip thing back, the one with the wiring, i see the wiring go further into the foglight... do i have to unscrew the two inside screws to replace the bulb?
May 31, 2008 - 2:57 AM |
Enthusiast Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) |
im in the process of installing my foglights on my 95 celica and i was wonderingg... how do u replace the foglight bulbs? i cant find it on the forums so im assuming im the only one having this problem. i know its kinda stupid, but for some reason i cant find out how!? after i twist it and move the black grip thing back, the one with the wiring, i see the wiring go further into the foglight... do i have to unscrew the two inside screws to replace the bulb? no dont undo screws look inside you will see a retaining bar clip push it down and move it to one side then pull the bulb out its just spring loaded hth -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:32 PM |
