> 7afe fuel filter
post May 31, 2008 - 1:02 PM
zoik
Joined Aug 28, '07
From france
hey can someone tell me where the fuel filter is and how do i replace him?
thanks
post May 31, 2008 - 1:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (zoik @ May 31, 2008 - 1:02 PM) *
thanks
fuel filter is behind/under the stock air filter assy.
you'll need 10mm, 17mm, 19mm wrenchs
and 10mm socket ratchet and extension
remove the top banjo bolt with the 19mm and 17mm wrenches
remove the bracket assy
remove the bottom fuel line with the 10mm and 19mm wrenches
install is the reverse of removal
post Jun 6, 2008 - 1:25 AM
selik
Joined Jun 4, '08
From Venezuela
QUOTE (stephen_lee @ May 31, 2008 - 2:14 PM) *
thanks
Hello!, do i need to remove the air filter assy to replace the filter? or it isn't necesary? i'm talking about the 2.0 engine... And the tank fuel filter, how many miles last before it need to be replaced?
Thanks!!
This post has been edited by selik: Jun 6, 2008 - 1:32 AM
post Jun 7, 2008 - 4:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah, its needed to remove the air filter. its quite easy really.
and the fuel pump strainer? im not sure on that one.
post Jun 10, 2008 - 5:51 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Get a line wrench if you have one, that bottom nut on the fuel filter SUCKS trying to get it loose
post Jun 11, 2008 - 12:55 AM
selik
Joined Jun 4, '08
From Venezuela
Lo-Fi Version Time is now: November 24th, 2024 - 2:24 AM
