> Wrecked Battery connector
post Jun 2, 2008 - 3:18 PM
Racer_J
Joined May 16, '07
From Newcastle UK
Hi all,
A friend of mine has just wrecked one of my battery connectors trying to fit a battery that was TOO BIG! He's forced the connector of the positive lead over the terminal of the battery and snapped it!
I don't suppose these can be easily replaced can they?
post Jun 2, 2008 - 3:27 PM
D-Man
Joined Jan 18, '08
From Houston
Snapped the battery post or the post connector on the battery cable?
The connector is dime a dozen and should take up-to and including 2 min to replace.
If it was the battery post itself, then you'll be needing a new battery sir.
Good luck and have fun.
Damn D-Man - most impressive.
post Jun 2, 2008 - 3:34 PM
Racer_J
Joined May 16, '07
From Newcastle UK
Hey, thanks for the quick reply!
Yep, it's the connector on the cable that's shagged..
I need to get my arse in to gear and get it sorted out! Thing is, I'm in work all week so won't have the chance!
post Jun 2, 2008 - 3:38 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (D-Man @ Jun 2, 2008 - 4:27 PM) *
Unless it's one with dual setups to accommodate side post connectors in which case it's an hour fix tops to relocate and put a new connector on the harness. wink.gif
QUOTE (Racer_J @ Jun 2, 2008 - 4:34 PM) *
Dude you seriously could go, buy the part and change it out in your lunch hour. If you can change a tire this is not much of a stretch from there. wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 2, 2008 - 3:55 PM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE (DEATH @ Jun 2, 2008 - 9:38 PM) *
I know, I know....
I don't work anywhere near any spares places!! I'll have to wait till I get in from work. (I feel an early finish coming on)
post Jun 2, 2008 - 4:34 PM
D-Man
Joined Jan 18, '08
From Houston
Honnestly, you can cheap out and spend like $3.00-$5.00 and it'll take 5 min and a wrench for a cheapo one. Litterly you'll cut the old one off, strip a peice of the cable in question, then slap it into the new conector and spin your wrench a few times. Then slap it onto the batt and spin that wrench a few more times. Done. It'd take all of 5 min. You
Lo-Fi Version Time is now: November 27th, 2024 - 6:38 PM
