> Broke Down
post Jun 2, 2008 - 10:17 PM
Capone
Joined Apr 13, '08
From Atlanta,Ga
So tonight me and my mom decided to drive to DQ in my car and we made it about a mile from my house and the car started makeing a noise and the pedals started shakeing. The noise was like a sound a car makes when you drive over a newly paved road with wet tar except the noise was comeing from my engine. This is probably the 10th time Ive ever driven the car and about 5 of those times was in parking lot learning to drive a stick. The car just had 2,500 worth of work done. Ive only had it for about 2 months frown.gif
post Jun 2, 2008 - 10:29 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
what rpm were you at? did it die? are you leaking oil? did it lose power, anything hanging down?
post Jun 2, 2008 - 10:51 PM
Capone
Joined Apr 13, '08
From Atlanta,Ga
I was not pushing it hard although i dont know what RPM i was at. I went form 1st to 2nd gear and about 1 second after it did that it started makeing that nosie, it kinda sounded like somthing was being shreaded or bouncing all around in there. And I didnt look under the hood cuz #1. I wouldnt know what hell i was looking at (im new to these things) and #2. it was night time and i was on the side of the highway so I wouldent be able to see anything. My mom is gonna call AAA in the morning and get it towed to the local shop. Got any idea what it could be? I know im not that big of a help but im trying to describe it as best I can. The car didnt actually die but I didnt keep driving it because I didnt want to make it worse, It sounded really bad frown.gif
post Jun 3, 2008 - 12:31 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
man couldnt tell you for sure. hope its nothing serious! pictures can help a little. did it stop when you stopped moving or when you cut the engine off?
post Jun 3, 2008 - 12:48 AM
CelicaST_CALI
Joined Feb 28, '07
wat work did u have done on it,u could have bad motor mounts but that would be shaking continually...when u pushed in the clutch did it stop shaking??when u were learning did it ever do anything weird?
BANNED. for life, you moron.
post Jun 3, 2008 - 11:51 AM
Capone
Joined Apr 13, '08
From Atlanta,Ga
The car just got towed. The noise would stop when the car was off but as soon as I started it again(I had to pull further off the road) the car would do it again. The list of things that just got fixed are: Replaced water pump, timeing belt, seals and oil pump seal and gasket, replaced valve cover gasket, Replaced clutch asslembly and rear engine main seal, resurfaced fly wheel, replaced valve cover gasket, and new radiator and thermostat. I pulled the list out of my car before they towed it. All of those parts pluse labor came to $2,520.62
post Jun 3, 2008 - 12:17 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
damn. i wish i can actually hear it. so much easier to help you point out the issue then
post Jun 3, 2008 - 12:39 PM
Remy
Joined Jan 25, '06
From MN
Check your oil level first its kinda hard to tell from your description. tongue.gif
"To Protect And To Serve The Wealthy" -POLICE
post Jun 4, 2008 - 11:23 AM
Shigexile
Joined Oct 30, '03
From IL
trans maybe? (bc you said right after you shifted)
or maybe the spark plug got loose and shot out? (it makes that pavment/motorcycle sound)
post Jun 4, 2008 - 11:59 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
It sounds from the description like a bearing that's going out - you said you had the clutch replaced, and that the incident occurred when you shifted. Is it possible the throwout bearing is bad?
post Jun 4, 2008 - 3:57 PM
Ugglan
Joined Jan 8, '08
From Sweden
sound bad...hope it is easy to fix...be sure to let us know what the problem was
post Jun 5, 2008 - 9:04 AM
Capone
Joined Apr 13, '08
From Atlanta,Ga
The Good News Is that nothing is seriously wrong, it turns out that two of the drive belts snaped so it is only $33.38 in parts to replace. The Bad News is that the shop Charged $85.00 to put it in. In all costing $121.21. But I am very thankful that it was not something worse!
post Jun 5, 2008 - 9:11 AM
DEATH
Joined Dec 19, '07
From tx
Wait - they did all the work you described earlier and then charged you to fix their mistakes? If they didn't change the belts cause you opted not to that's your fault but if they changed the belts and installed them too tightly that's their fault. Who changes the timing belt, water pump etc and doesn't change the drive belts? Something sounds fishy.
I hate when mechanics take advantage of people who don't know engines/cars. mad.gif
This post has been edited by DEATH: Jun 5, 2008 - 9:11 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 5, 2008 - 10:09 AM
Capone
Joined Apr 13, '08
From Atlanta,Ga
When I brought the car in the first time it was to have the antenna fixed, but when he looked under the hood he said all the stuff I listed a few comments up needed to be replaced, so my mom told him to go ahead and fix it. He never mentioned anything about any belts (other than a timing belt). When I got the car back, my uncle looked at it and said that those things did need to be replaced.Then it broke down. When my mom talked to the mechanic yesterday he did say sorry he didnt catch the problem the first time but that was it. I wish I knew more about cars so I could work on it myself.
post Jun 5, 2008 - 10:26 AM
DEATH
Joined Dec 19, '07
From tx
Nah it's cool - the mechanic just should have known better than to replace the Tbelt but not the others while they were off anyway. I hope everything works great for a good long time now - that's the most important thing.
You're in the right place to learn about your car - many of us here couldn't change spark plugs when we came here [I have certainly learned alot even tho I had quite a bit of knowledge before hand].
EXT: WRC/TRD/404
post Jun 5, 2008 - 11:20 AM
Capone
Joined Apr 13, '08
From Atlanta,Ga
Thanks I hope they have worked out all the kinks so it runs for a good LONG time now. smile.gif
post Jun 5, 2008 - 8:03 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
holy 1.0 hr labor just to install 2 drive belts in a Celica?!?? I work at a dealership and we only charge 0.5 ($45) for the same and I already think that's too much.
This post has been edited by hurley97: Jun 5, 2008 - 8:04 PM
I <3 Dustin---07/16/06
post Jun 5, 2008 - 8:20 PM
monkey
Joined Nov 21, '07
From I-59 -N- 610 Houston, Tx
QUOTE (hurley97 @ Jun 5, 2008 - 9:03 PM) *
say what!!!!! i work at a toyota dealership and i only pay 10$ an hr for labor and thats from our best mechanic....
post Jun 5, 2008 - 8:32 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
$10/hr at a dealership is unheard of. where I work its $90/hr for customers and $61 for employees. Our master techs get paid around $25/hr so we can't charge anyone any less than that. But I work in the service dept so I pay $0 for labor wink.gif
post Jun 5, 2008 - 8:37 PM
monkey
Joined Nov 21, '07
QUOTE (hurley97 @ Jun 5, 2008 - 9:32 PM) *
ohh nice... i wish i was a mechanic... lol but naw charlie is a good friend of my fathers and he is usually working on the boss mans lil tinkre projects and supras, and land crusers and what nots... but ya, good thing he dont charge me much, cuz hes the only other person allowed to touch my car...
what position do u hold in service..
service writer, mngr, cust. relations..., service mech... porter... cashier?
Lo-Fi Version Time is now: January 9th, 2025 - 9:50 PM
