turbo direction, maybe stupid, but i'm gonna ask it |
Jun 4, 2008 - 9:50 PM |
Enthusiast Joined Jan 4, '08 From Lexington, KY Currently Offline Reputation: 0 (0%) |
Ok so I am curious bout something. I have a camry 5sfe in which I can run the same turbo setup you guys can with the execption of the downpipe. It has to be modified to go around my front engine mount. No big deal, but a pain. So I got to lookin online and noticed that some turbo kits for hondas have the turbo mounted with the exhaust exiting either side. Does it really matter which way the turbo faces? If it doesn't then I can take my spare B-series t3/t4 downpipe and modify it a hell of a lot easier and with less bends then the normal way all 5sfe turbo engine route theirs. Any help?
Jun 4, 2008 - 10:04 PM |
Enthusiast Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
not really understand what your talking about........
you want to basically turn the turbo around? pics of the setup? it doesn't matter which way it faces as long as the oil lines are in the right location This post has been edited by southwest2118: Jun 4, 2008 - 10:05 PM |
Jun 4, 2008 - 10:10 PM |
Well I don't have pics handy but on 5sfe's that are turbo the hot side is facing the passenger side and the cold in on the driver side. Can I just flip it around and put the hot side towards the driver and the cold towards the passenger?
Jun 4, 2008 - 10:23 PM |
Enthusiast Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) |
I think I know what you mean. The reason behind it is the cooling (intercooler/charge cooler) and/or routing to the inlet on the manifold. If you reverse (spin the turbo 180 degrees) then you would have a bit of a nightmare getting the pressurised air to the manifold via the cooler, also, this would incur more piping, more bends and more pressure drop.
-------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Jun 4, 2008 - 10:47 PM |
Pressure I hope you don't mind me using your photo but its the best one to give an examply of what I am trying to explain.
Take his turbo, with the hot side on the left and cold on the right. Now simply rotate it horizontal 180 degrees. From there the hot side is on the right and cold is on the left. Now I get to looking at it and the pipe from the cold outlet to intercooler now needs a tight bend. But I can clock the cold side 180 degrees from there vertically and just run a s pipe into a 45 and then into the intercooler. Now with doing that I have less piping and I don't have to finagle around my camry's front engine mount. I hope that is easier to understand and not confusing people anymore. I am just trying to find out if it matters which way the exhaust flows into and hot side. If the fins on the wheel are shaped to only grab air and turn one way better than the other, of it it doesn't matter which way the wheel spins. |
Jun 4, 2008 - 10:51 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
If you rotate the turbo 180 degrees you will have the turbo outlet face your oil filter.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Jun 4, 2008 - 11:05 PM |
Oil filter is relocated
Jun 5, 2008 - 2:09 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
Pressure I hope you don't mind me using your photo but its the best one to give an examply of what I am trying to explain. Take his turbo, with the hot side on the left and cold on the right. Now simply rotate it horizontal 180 degrees. From there the hot side is on the right and cold is on the left. Now I get to looking at it and the pipe from the cold outlet to intercooler now needs a tight bend. But I can clock the cold side 180 degrees from there vertically and just run a s pipe into a 45 and then into the intercooler. Now with doing that I have less piping and I don't have to finagle around my camry's front engine mount. I hope that is easier to understand and not confusing people anymore. I am just trying to find out if it matters which way the exhaust flows into and hot side. If the fins on the wheel are shaped to only grab air and turn one way better than the other, of it it doesn't matter which way the wheel spins. The turbine is design in a circular shape so whatever flows in it must follow that shape thus spining the fins in the direction its travelling so it doesnt matter how/where you mount it. -------------------- 98% completion --- aaRon |
Lo-Fi Version | Time is now: November 30th, 2024 - 12:00 PM |
