> Turning on A/C makes my car shake, whats wrong?
post Jun 5, 2008 - 6:25 PM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
when i turn on my a/c i can feel the car vibrate and when i turn it off it returns to normal. if im in motion, i cant and dont notice the change in vibrations but if im at a standstill my car begins and continues to vibrate more than normal until i turn it off. as soon as its off, the vibrations stop. what do i do? it still blows cold and doesnt blink ever. thanks guys!
post Jun 5, 2008 - 6:47 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
mine does it too, I think air conditioners take a bit of power when on and make your car slower so shaking on idle may be normal.
post Jun 5, 2008 - 6:51 PM
Remy
Joined Jan 25, '06
From MN
The A/C drains alot out of your car, if its little vibration its normal.
"To Protect And To Serve The Wealthy" -POLICE
post Jun 6, 2008 - 1:00 AM
NaderG
Joined May 13, '07
From riverside, ca
i know that when u turn on your A/C, it is supposed to adjust your car's idle accordingly in order to counter the stress the A/c puts on your engine. But i still dont know which vacuum line does it and how it control it , so my car shakes as well smile.gif
post Jun 9, 2008 - 9:52 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
Check you AC idle up. can't get onto bgb again for some reason, so I can't tell you 100% what to do. The A/C idle up is a VSV AFAIK, and is located against the firewall, by the diagnostic box. Check the vac lines running to/from there, and try adjusting the screw on it.
post Jun 10, 2008 - 12:18 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
on my ST the AC idle up valve is on the firewall right behind the intake manifold.
Lo-Fi Version Time is now: November 26th, 2024 - 9:53 PM
