> Will 16" 7th gen GTS rims clear ST205 brake calipers?
post Jun 6, 2008 - 11:34 PM
azian_advanced
Joined Apr 18, '05
From Calgary
as the title states.. does anyone know?
post Jun 6, 2008 - 11:43 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
hmmmm really good question......
you know how much taller/wider the 205 brake are compared to the 204s????
post Jun 7, 2008 - 8:58 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i know that the stock st205 rims are 16" but i'm not sure if it's wide enough to clear the calipers.
post Jun 7, 2008 - 5:11 PM
Valo666
Joined May 15, '05
From Toronto
the factory gt4 wheels are 16x8 i belive, and im not sure how wide the 7th gen wheels are. Worst comes to worst, you will have to put a spacer in.
post Jun 7, 2008 - 6:39 PM
I'm 99% sure they won't clear, unless you get a spacer like Bryan said.
post Jun 8, 2008 - 2:43 AM
stevest202
Joined Oct 28, '07
From epworth uk
definately would need spacers to clear caliper
post Jun 8, 2008 - 4:10 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
gts = 16x 6.5
somewhere along that width
This post has been edited by 808celica: Jun 8, 2008 - 4:10 AM
post Jun 8, 2008 - 10:28 AM
azian_advanced
Joined Apr 18, '05
From Calgary
thanks for the input guys.. i had a hunch that the 7th gen rims were too narrow.
post Jun 12, 2008 - 7:35 AM
qatar11
From Lake Orion, MI
While trying to move both halves of my ST205, I was using my 7th Gen GTS Wheels as I didn't have any other wheels lying around. They for a fact do not fit, I had to remove not only the caliper but the rotor as well.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Jun 12, 2008 - 2:54 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
aren't st205 rotors like ~12 inches? (really want to say 14" but that seems to large)
edit: changed my numbers
This post has been edited by devilsden97: Jun 12, 2008 - 2:55 PM
Kawi Love
post Jun 17, 2008 - 12:29 PM
qatar11
From Lake Orion, MI
QUOTE (devilsden97 @ Jun 12, 2008 - 3:54 PM) *
13" I believe
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Jun 17, 2008 - 4:27 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
well they fit on the ST204 just nicely
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 17, 2008 - 7:19 PM
devilsden97
Joined Jun 13, '05
QUOTE (Smaay @ Jun 17, 2008 - 5:27 PM) *
learn to read.
Kawi Love
post Jun 21, 2008 - 11:29 PM
Shigexile
Joined Oct 30, '03
From IL
QUOTE (Smaay @ Jun 17, 2008 - 4:27 PM) *
They were refering to the st205, but you have a full tank of gas so its okay if you give me half tank.
post Sep 16, 2015 - 10:53 PM
azian_advanced
Joined Apr 18, '05
From Calgary
back from the dead.
i just had a forum member ask if I ever got this sorted out, which i never did.
but going back to the original question, it's not too hard to figure this out.
didn't know about wheel width & offset at the time i made this thread.
so, suppose you're mounting a 7th gen GT-S wheel on a stock ST205, then you'll need a minimum of 7mm spacers to get the same caliper clearance as a stock st205 (assuming no difference in wheel spoke design/concavity).
this is based on comparing the two wheels specs below and running the math:
st205 oem wheel specs are 16" x 7.5" +45.
7th gen GT-S wheel specs are 16" x 6.5" +39.
since i don't know what the st205 oem caliper clearance is, there's a chance that spacers aren't even required at all.
but it would be wise to at least aim at getting the same as oem clearance and for that, go with a minimum of 7mm spacers, or 10mm since spacers are usually sized in 5mm increments.
although, i'd go with wider spacers to achieve the "flush" look.
This post has been edited by azian_advanced: Sep 16, 2015 - 10:56 PM
post Sep 18, 2015 - 11:00 PM
This is useless without a source but I believe someone here tried and they did not fit.
post Sep 19, 2015 - 10:34 PM
mi645
Joined May 23, '12
From northridge,CA
No it wont due to offset, wont clear caliper
Lo-Fi Version Time is now: February 20th, 2025 - 12:54 AM
