> Bad coil
post Jun 9, 2008 - 8:35 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
Hi, i know the test for the coil from the bgb guide says the primary coil resistance should be between .41-.5, I got .7, and for the second coil if should be between 10-14, but i got 14.28, so basically does that resistance difference tell me its a bad coil?
post Jun 9, 2008 - 9:43 PM
alltracman78
Joined Aug 9, '06
From Ma
Assuming you did it correctly, and use the right ranges, yes [barely]. smile.gif
If you're car's running fine, don't worry about it.
If you have ignition problems, I'd replace it.
post Jun 9, 2008 - 10:25 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
ya i am having iginition problems, thanks i am gonna replace it
post Jun 10, 2008 - 10:50 AM
DEATH
Joined Dec 19, '07
From tx
MSD Blaster II is a cheap and good way to replace your coil. I'm not saying it's much of an upgrade but just much cheaper than stock and it's only like two connections to make and they are retarded easy. Make sure you get the one with the spare connectors for the coil wire so that you can adapt your existing coil wire. wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 10, 2008 - 12:14 PM
I think I have a gt coil laying around. Pm me if you need it.
Lo-Fi Version Time is now: November 24th, 2024 - 7:27 PM
