DC to DC converter |
Jun 9, 2008 - 8:51 PM |
Enthusiast Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
i have a wideband and it will not work at anything under 13.5 or so volts. so I'm thinking of building or buying a dc to dc converter something that will take battery voltage 12-14v and give me a constant 14v ....any body have any ideas??
http://www.rowan.sensation.net.au/electronics/stepup.html I'm pretty good at reading car wiring diagrams but this is another language |
Jun 10, 2008 - 12:35 AM |
you're looking at a much more advanced diagram than your typical car wiring diagram..
if you're looking at building something like in the 1st diagram, you'd need to be at least in your 2nd year of an electrical engineering program to fully understand it.. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jun 10, 2008 - 12:38 AM |
Enthusiast Joined Nov 21, '07 From I-59 -N- 610 Houston, Tx Currently Offline Reputation: 0 (0%) |
haha if anyone on here could figure it out, itd be dr tweak...
Jun 10, 2008 - 12:53 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
lolz all i can recognize are the inverter gates. those are the triangles with circles at the tip. the rest can probably just be googled, for example http://www.autoshop101.com/forms/elec07.pdf is from a google search "digital wiring diagram legend". just takes time to learn. btw CS major not exactly ECE.
Jun 10, 2008 - 12:57 AM |
ya but the hard part is knowing what kind of fuse/ inverter/resistor to use.. ur dealing with all sorts of ohms volts watts currents and polaritys and ampers, i just leave that stuff to the pros,
but if u wanna attempt it than i say go for it! why not give it a try! |
Jun 10, 2008 - 1:04 AM |
so basically the problem is that your gauge won't work unless it has over 13.5 volts? why bother since your car when it runs is 14v and when it's off the battery should be 12.5v. i don't really get the problem.
as long as your car is on the gauge will work. is it installed? |
Jun 10, 2008 - 5:29 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Wow, that seems like a lot of work, why not just wire up a resistor in line?
Jun 10, 2008 - 5:37 PM |
check this out. it produces constat 12v from sources of 6 to 9. Maybe a couple of resistor changes can get your desired voltage. contact the guy...
http://dion.swamp.dk/carpower.html -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:50 AM |
