How do you program new remote?, factory alarm |
Jun 10, 2008 - 1:01 PM |
Enthusiast Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
Toyota Dealership wants me to make an appointment for something I know only takes 5 minutes. I just need to know where the box is, and what the "sequence" is to program my new remote (that the dealership raped me for)!
Thanks |
Jun 10, 2008 - 1:51 PM |
the box is under the driverseat.
1. Insert key into ignition, turn it to on(not acc) 2. On your ECU unit, gently push the button with the tip of a paper clip, pen, etc, for about 3 seconds until the light on the TOYOTA SECURITY panel lights up. You now have about 30 seconds to press the button on your new remote once) to tell the car to recognize it. 3. remove key from ignition 4. step out of car and test your remote that should do it. -------------------- |
Jun 10, 2008 - 2:27 PM |
Dude, you are a life saver! Thanks!
Jun 10, 2008 - 3:47 PM |
No problem. did that one work? because i also remember one where you had to open and close the door 5 times or something then unlock and lock it 3 times then go back and forth from off to Acc with the key 5 times then you could program it.
Jun 10, 2008 - 4:05 PM |
This information is SUH-WEEEET!!!!
Jun 10, 2008 - 6:16 PM |
It worked PERFECT for my new (to me) 98 GT! Thanks again!
BTW, I think this could maybe be a sticky? |
Jul 5, 2008 - 10:42 AM |
Enthusiast Joined Oct 3, '07 From Ireland Currently Offline Reputation: 0 (0%) |
Ok tried looking for that box, no joy!
Could you post a pic of what the box under the seat looks like? I took apart the dash looking for a control box with a button but nothing... not a zip? The car doesnt have an aftermarket alarm for sure, the toyota security led is there and no aftermarket boxes anywhere. All the boxes are labeled TVS-IIIB, again not one with a button |
Jul 5, 2008 - 10:56 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
Ok tried looking for that box, no joy! Could you post a pic of what the box under the seat looks like? I took apart the dash looking for a control box with a button but nothing... not a zip? The car doesnt have an aftermarket alarm for sure, the toyota security led is there and no aftermarket boxes anywhere. All the boxes are labeled TVS-IIIB, again not one with a button In mine it sits on top of the ECU under the centerdash, black box. Not really a button that you can push with ur finger, you need a pen or something small. -------------------- 98% completion --- aaRon |
Jul 5, 2008 - 7:59 PM |
hmm does it look like this???
This box I found just above the air vents in the center dash, theres a "key transponder" box on the passenger side. I found no buttons on either!? I even unscrewd that one and opened it up the only button looking thing is a set of dip-switches which I take are for setting the frequency. |
Lo-Fi Version | Time is now: January 14th, 2025 - 5:29 PM |
