> Exhuast Noise???
post Sep 8, 2003 - 12:33 PM
TRDCelicaST
Joined Mar 21, '03
From Pittsburgh, PA
I had a custom cat-back put on about 2 weeks ago, and instead of going with a magnaflow muffler I went with one the owner of the shop had suggested (Arvin). Although I've never heard of Arvin he insisted it was very similar to the magnaflow. My problem is when the car is almost at WOT I hear a loud clicking noise coming from the muffler but the sound only shows up around 3,000 RPM and then fades out a little after 4,000 and only when the car is close to WOT. I talked to the guy at the shop and even had him ride in the car with me. He says that it's because it's a 4 cyl. motor, but I've never heard this sound come out of any 4 cyl. before. He says if I put a resonator on, that most of the clicking will go away. But it's not a sure thing. I'm kinda stuck here and am wondering if I should just get the magnaflow ($130) or have him put the resonator ($25) on. Has anyone had this kind of problem before? What do you guys think I should do about this? I just dont want to have the resonator on and still have this annoying noise coming from my car and then have to buy a new muffler too.
post Sep 8, 2003 - 4:10 PM
Hanyo
Joined Aug 16, '03
From Bay area
this sounds like the exhaust system is vibrating at the cat back. this usually happens around 3k-4k rpm.
what size piping did u use and how big is the opening at the muffler?
some things to check are the bolts that hold the cat. to the rest of the exhaust system, and all the hangers are in place.
My friend had the same problem, what he did was replace his muffler. It has something to do with the exhauste waves bouncing back up the pipe from the muffler and rattling the cat-back connection.
post Sep 8, 2003 - 4:54 PM
TRDCelicaST
Joined Mar 21, '03
From Pittsburgh, PA
I used 2.25" piping from the cat back and the opening is 2.25" too
This post has been edited by TRDCelicaST: Sep 8, 2003 - 4:59 PM
post Sep 8, 2003 - 6:37 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (TRDCelicaST @ Sep 8, 2003 - 2:54 PM)
Check the piping. It could just be rubbing on a heat shield or something.
post Sep 8, 2003 - 6:42 PM
Junior
Joined May 5, '03
From Toronto
Rip off your heat shield. Its a common problem. Your car will run just fine with out it.
Lo-Fi Version Time is now: December 3rd, 2024 - 11:31 PM
