> boost, boost for 5sfte
post Jun 15, 2008 - 4:02 AM
xxFROZENxx
Joined Nov 13, '06
From AUSTRALIA(MELB)
hey guys just want to know what is the minimum and maximum boost for a 5sfte? and also what is the stock boost? thanks
post Jun 15, 2008 - 7:56 AM
QUOTE (xxFROZENxx @ Jun 15, 2008 - 5:02 AM) *
the correct answer is 0.
there IS no minimum or maximum. or "stock" boost level for that matter.
its all dependant on the parts you add to the 5s to make it a turbo engine.
post Jun 15, 2008 - 2:08 PM
terqui
Joined May 23, '06
Stock boost is actually 14.7 psi as it is for all cars. That is stock atmospheric pressure.
post Jun 16, 2008 - 7:07 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE (terqui @ Jun 15, 2008 - 3:08 PM) *
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 16, 2008 - 10:31 AM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
QUOTE (DEATH @ Jun 16, 2008 - 6:07 AM) *
or if your metric it would be 1 Bar I think..
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Jun 16, 2008 - 11:14 AM
actually, no.
the term "boost" represents anything above "atmospheric pressure"
anything below "atmospheric pressure" would be vacume.
post Jun 16, 2008 - 11:25 AM
D-Man
Joined Jan 18, '08
From Houston
Also, atmospheric pressure changes depending on how high over or below sea-level you are, yeah? So any assigned PSI would only apply to the car at that same location that it was measured. But someone across the country, say near the sea or on top a mountain, would have varying results.
Damn D-Man - most impressive.
post Jun 16, 2008 - 9:07 PM
CelicaGT04
Joined Nov 22, '05
From Mesquite, Texas
I LOVE THE INTERNET!!! WE CAN ALL SEE HOW SMART IT MAKES US SOUND!!! laugh.gif laugh.gif
Presure2 is right, since the 5sfe is initially a N/A car. Wouldnt it be smart to assume it really has no reliable stock, minimum, or maximum boost. Just a variation of quality of parts and efficiency of tune will allow for your 5sfte to achieve stable stock boost, maximum boost via your motor and tune..
post Jun 17, 2008 - 3:21 AM
xxFROZENxx
Joined Nov 13, '06
ok guys .. my tuner says just run 8-9 psi atm with the safc..to run more boost he want me to upgrade my piggyback ecu so he has more room to play with.. what piggyback ecu should i buy? is a greddy ultimate good? and also i notice my clutch is slipping... what clutch do you guys recommend i should get? i found some clutch kits in the US ebay site.... are they any good? thanks..
post Jun 17, 2008 - 8:41 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i would never get a clutch from Ebay. i suggest Southbendclutch.com click on the import link and give Andy a call. he will get you what you need. i have a southbend in my All-Trac, my 600HP celica, and my supra. i love them. excellent customer support and service too
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 18, 2008 - 10:05 AM
CelicaGT04
Joined Nov 22, '05
QUOTE (xxFROZENxx @ Jun 17, 2008 - 4:21 AM) *
SAFCII is more than all you will need for your 5sfte i would say. But then again, thats just my .02!
post Jun 19, 2008 - 1:16 AM
xxFROZENxx
Joined Nov 13, '06
im running a safc1 already... what the differences in a safc 1 and 2?
post Jun 25, 2008 - 1:29 AM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
QUOTE (xxFROZENxx @ Jun 19, 2008 - 6:16 AM) *
you should check out AEM's fuel/ ignition controler it is a piggy back system which is basicly for n/a cars being boosted they have an on board map sensor and out perform's the safc's and neo that just came out due to the programing and they are alot easier and reliable compared to the other piggy back's just go to aempower.com and look up aem F/IC
post Jun 26, 2008 - 8:59 AM
CelicaGTS94
Joined Aug 26, '03
From N.B Canada
SAFC2 is a decent unit for minor tuning, not to mention cheap if your gonna be running low boost that is. I saw no need to spend $1000 or so on a stand alone just to run 7-8 PSI. Wish I had someone around here who knows how to tune the SAFC2. I have tried a few things,like standard setup and such. But don't want to mess things up and hurt the car. I have had it in the car for almost a year now, with no one to tune it. I plan on running a 5sfte, but i want to get a fresher motor than swap it. I already have all I need except BOV and cooler pipe! oh yes and the new 5sfe!! wonder where I could get a decent one. anyone ever deal with Tiger japanese?? they have decent prices.
This post has been edited by CelicaGTS94: Jun 26, 2008 - 9:01 AM
post Jun 27, 2008 - 12:33 PM
CelicaGT04
Joined Nov 22, '05
QUOTE (CelicaGTS94 @ Jun 26, 2008 - 9:59 AM) *
Lo-Fi Version Time is now: November 25th, 2024 - 2:20 AM
