> Removing the stock antenna, Can't do it
post Sep 8, 2003 - 4:15 PM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
I fiddled around with the stock antenna for awhile trying to get it off, but I never had any luck. Can someone tell me how to get it off?
post Sep 8, 2003 - 4:40 PM
Mynzeyes
From Franklin/Nashville, TN
-John-
AIM==Mynzeyes
post Sep 8, 2003 - 5:03 PM
Delta_Phoenix
Joined Oct 16, '02
I see "Replies: 1". I get optimistic. I think I'll just go cut it off w/ the Dremel.
post Sep 9, 2003 - 3:05 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
There is a nut on the top of the nub that stick out from the fender. It's got a couple of cuts in it for a special socket to pull it off. If you're carefull pliers work also, the hardest part is get it to break loose. Inside the trunk pull the left side plastic and you'll see the bracket assy the motor is attached with.
Lo-Fi Version Time is now: November 29th, 2024 - 4:09 AM
