> lack of knock sensor on 5S-FE
post Jun 16, 2008 - 10:55 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
so those of you with 5S-FTE's how do you monitor knock while tuning and every day driving?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 16, 2008 - 11:03 AM
all 94-99 5sfes have a knock sensor
the earlier 5s (5th gen) do not
QUOTE (Smaay @ Jun 16, 2008 - 11:55 AM) *
post Jun 16, 2008 - 4:14 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
ah good to know, thanks
post Jun 16, 2008 - 4:33 PM
DEATH
Joined Dec 19, '07
From tx
OK Batman but can the 94-95's [OBD-I] pull timing back to correct for knock the way the OBD-II's do?
this is relavent to a 5S-FTE I'm assisting with the build on. My old OBD-II Celica did of course and I'm hoping this OBD-I car will as well. I know it's no substitute for a good tune but it's nice as a backup.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 16, 2008 - 4:37 PM
alltracman78
Joined Aug 9, '06
From Ma
Has nothing to do with OBDI or II.
If it has a knock sensor it can [and will] pull timing if it senses knock.
QUOTE (Batman722 @ Jun 16, 2008 - 12:03 PM) *
5th Gens do also.
92 and later 5SFEs have a knock sensor.
post Jun 16, 2008 - 4:42 PM
DEATH
Joined Dec 19, '07
From tx
Thanks Alltracman. I was aware that OBD had nothing to do with it but I did know that the ECU's handle timing differently [Try changing your base timing on both and keep the light on for a few minutes afterwards and you will see what I mean] so I wasn't sure if it was within the capabilities of the older ECUs.
Makes sense tho - what would it need the knock sensor for if it had no way to use it's output.
EXT: WRC/TRD/404
post Jun 16, 2008 - 4:45 PM
alltracman78
Joined Aug 9, '06
From Ma
OBDII won't let you change your base timing, it will adjust back because it has a crank sensor.
post Jun 16, 2008 - 4:48 PM
DEATH
Joined Dec 19, '07
From tx
I knew you knew that laugh.gif But I was just explaining my reason for double checking.
EXT: WRC/TRD/404
post Jun 16, 2008 - 5:01 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
more good info, hopefully my little project will go smooth
Lo-Fi Version Time is now: November 27th, 2024 - 1:44 PM
