right hand conversion |
Sep 8, 2003 - 8:30 PM |
Enthusiast Joined Aug 29, '03 From california Currently Offline Reputation: 0 (0%) |
how much would it to be to covert a right hand drive to a left hand drive?
Sep 8, 2003 - 8:47 PM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
I'm sure it would be a lot... but I don't know if anyone has actually attempted this feat with a 6th gen... I would guess at least $1200... depending on the shop... |
Sep 11, 2003 - 8:49 AM |
ya the labor alone would be a lot then getting a st205 front clip as well.
Oct 2, 2003 - 10:49 PM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
I have a friend that is doing this to a prelude.. what you need is a full front clip.. you will need the dash and everything forward from it... you will have to cut out the firewall and have the one from the 205 welded in.. you might also need to cut the cowl... the steering linkage shouldn't need to be changed or anything in the actually engine bay.. the shifter and everything is the same so no need there.. you should probalby invest in the JDM door panels and control boxes on the doors to keep the conversion true.. if you know how to wield and have a full clip then you could do this yourself.. otherwise its gonna cost more the 1200 to have a shop do it for you
-------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Lo-Fi Version | Time is now: November 25th, 2024 - 1:00 PM |
