Converting to rear discs, Using ABS calipers |
Jun 22, 2008 - 1:22 PM |
Enthusiast Joined May 23, '06 Currently Offline Reputation: 0 (0%) |
Is this possible? If so what issues might i run into when doing the conversion?
Jun 22, 2008 - 1:25 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
idk about the abs calipers but use the search function.here is one doggy did :
http://www.6gc.net/forums/index.php?showtopic=27749&st=0 -------------------- BANNED. for life, you moron.
Jun 22, 2008 - 8:30 PM |
Im asking because i came across some ABS rear discs and I wanna see if they'll work.
Jun 23, 2008 - 2:56 PM |
Enthusiast Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
they will work buddy abs is controlled by the ecm to the abs module no module means no signal to the ecm therefore they will work
Jun 23, 2008 - 3:24 PM |
Isn't there a wheel speed sensor associated to the brakes though? I'm not sure if they just go on the front wheels on ABS equipped cars or on all 4, but that's something to take into consideration. I'm sure you can remove the sensors from the rears, just keep in mind they might be there
Jun 23, 2008 - 3:27 PM |
yeah ther are there but it doesnt matter seeing as the signal would be sent to nowhere i asked my shop foreman and he confirmed
Lo-Fi Version | Time is now: January 10th, 2025 - 3:13 PM |
