![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) ![]() |
I have an Alpine 9870 headunit with 6.5" Infinity Reference speakers in the front, and whenever certain bass and treble kicks in, there is this distortion, which I feel is to blame from the adjustment of the bass and treble frequencies.
According to my user manual, I can adjust the bass center frequency, bass bandwidth, along with treble center bandwidth, and high pass filter. Here are my choices for each: Bass center frequency: 80hz-->100hz-->200hz-->60hz-->80hz "Emphasizes the displayed bass frequency ranges." Bass bandwidth: 1(narrow)-->2-->3-->4(wide) "A wider setting will boost a wide range of frequencies above and below the center frequency. A narrower setting will boost only frequencies near the center frequency." Treble center frequency: 10.0khz-->12.5khz-->15.0khz-->17.5khz-->10.0khz "Emphasizes the displayed treble frequency ranges." High pass filter: 80hz-->120hz-->160hz I think the high pass is only for if you have a subwoofer, so I don't need to adjust it? What settings should I have for everything else, though? I have the Infinity's in the front, and plan on adding some JBL's to the back. BTW, the sensitivity of these speakers is 93db, and the frequency response is 53 - 21k Hz. -Matt This post has been edited by GotToyota: Jun 22, 2008 - 5:23 PM |
Lo-Fi Version | Time is now: February 17th, 2025 - 7:24 AM |
