> white smoke only when starting up...
post Jun 23, 2008 - 12:34 AM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
My car runs perfectly never had any problems..but when i start my car up it emits white smoke for a few seconds then stops, and it never does it while im driving. Should i just use sea foram next time i get my oil change and see if that does the trick? and just so i dont have to start up anouther thread... I am new to exhaust mods. I saw this in anouther thread a just have a few questions. Someone mentioned this brand and i found the exhaust on ebay http://cgi.ebay.com/ebaymotors/MAGNAFLOW-M...sspagenameZWD1V ..Is this a direct bolt on..and would i need to buy anything else to install it. Sorry for bieng a newb and as usual thanks for the help.
post Jun 23, 2008 - 8:44 AM
for the smoke, your valve seals are bad. Not easy to change out.
That link is just a muffler. You would need to cut your old muffler off and have that one welded on in it's place.
post Jun 23, 2008 - 9:25 AM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
Is there something i can get that is a bolt on and doesent require welding?
post Jun 23, 2008 - 11:19 AM
Jared95
Joined Apr 24, '07
From lufkin tx
QUOTE (Athorn @ Jun 23, 2008 - 3:25 PM) *
that would be a negative your going to have to take the exhaust that you buy up to a local muffler shop and they will weld it on for you it normally is pretty cheap just to hack off your old tip and install a new one they did mine for $30 i believe.
post Jun 23, 2008 - 6:33 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Depending on the thickness and smell of the smoke (which are hard to explain in words), it could also be carbon buildup on the valves or just condensation from the converter both of which are pretty normal conditions. If it's valve seals you will notice a little bit of oil consumption along with it. Just know that using 1qt of oil every 1200-3000 miles is considered acceptable by Toyota's standards, anything more than that is cause for concern.
I <3 Dustin---07/16/06
post Jun 24, 2008 - 6:41 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
QUOTE (Athorn @ Jun 23, 2008 - 10:25 AM) *
You'll spend more money getting a bolt-on VS just having someone weld one for you.
post Jun 24, 2008 - 11:05 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
cost me 25 to get one weilded on its cheap that price does not include muffler itself....the muffler is a seperet check
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Jun 24, 2008 - 1:09 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
Is the a decent muffler? Im on a budget and for the price it looks good. http://cgi.ebay.com/ebaymotors/MAGNAFLOW-M...sspagenameZWD1V
post Mar 6, 2009 - 1:56 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
couldn't determine how serious the problem is...
I'm pretty sure i've got bad valve seals because I get the start-up smoke and dont' have a bad idle, although its a little high. Are bad valve seals just something to live with i.e. topping off oil or is it something that should be replaced sooner than later? I plan to replace them on my next TB/WP but should I do it sooner?
post Mar 6, 2009 - 2:02 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE (99Celica @ Mar 6, 2009 - 2:56 PM) *
I just put my celica in the garage to get new valve seals as well as a build. I had blue smoke at start up for about 10 seconds. The guy gave me a call and said it was in fact the seals. It's pretty expensive and if I wasn't doing a build on it, I wouldn't have bothered because i was only loosing about a teaspoon of oil a week.
post Mar 6, 2009 - 3:24 PM
99Celica
Joined Nov 1, '07
ok I just wanted to confirm that the only thing it causes is oil consumption and obviously not optimum performance, and my engine isn't in danger short or long-term.
post Mar 7, 2009 - 10:49 AM
6G96GT
Joined Jan 20, '08
From East Coast
I don't think so...I would drive it casually I guess, I wouldn't go rompin on it or anything. You never know if you could totally blow out those seals? I heard something about the seals get real hard and then can break causing more issues.
post Mar 9, 2009 - 5:26 PM
SL44
Joined Dec 26, '06
From West Covina, CA
I've had the blast of white exhaust smoke for a couple of years now. I'll live with it and continue to change the oil every 5000 miles.
Lo-Fi Version Time is now: November 26th, 2024 - 12:23 PM
