> GT-FOUR owners, I need your help
post Jun 23, 2008 - 5:46 AM
Keijukainen
Joined Jun 20, '08
From Moscow, Russia
hi, everyone!
I've got an APEX'i AVC-R boost controller. Would you be so kind as to share your adjustments/figures with me if anyone got the same device? I'm interested in duty figures most
thanx in advance
post Jun 23, 2008 - 3:47 PM
Insanity-74
Joined Jan 9, '05
From Under the car
1.1 bar at 57% duty
1.3 bar at 63% duty
But these are the settings I used to use....all of them if its any help
Setting [A] 0.9 Bar
Boost /Duty Cycle
Bst = 0.90kg/cm2
Duty = 52%
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
Set to 0% in all
Setting [B] 1.1 Bar
Boost /Duty Cycle
Bst = 1.10kg/cm2
Duty = 60%
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
Set to 0% in all
Etc settings
Car Select
Cyl = 4
Spd = 5
Throttle = / (arrow pointing up to the right)
Sensor Select
Number one (1)
Gear Jdge
1st = 120
2nd = 075
3rd = 050
4th = 035
5th = 025
N/S = 255
Graph Scale
BS = 2.0kg/cm2
Ne = 8000 RPM
Sp = 300km/h
Monitor
2 Channel
1 Bst
2 Rev
This post has been edited by Insanity-74: Jun 23, 2008 - 3:48 PM
post Jun 24, 2008 - 12:54 AM
Keijukainen
Joined Jun 20, '08
From Moscow, Russia
Lo-Fi Version Time is now: November 25th, 2024 - 11:51 AM
