> Replacing catalytic converter?, Doing a full exhaust system
post Jun 24, 2008 - 5:57 PM
Legit94GT
Joined Feb 6, '08
From Oregon
So i have been told something different from every shop i've talked to now and am getting a little fed up...
So some shops have told me that i wont need to buy a new catalytic converter
Others say they will inspect it and see
And the rest tell me i will HAVE to have a new one
So for anyone who has done an exhaust system if you could give me your two cents on the matter it would be really appreciated:)
car is in perfect running shape, and has 90xxx miles on it...
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Jun 24, 2008 - 7:07 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Hey man, are you talking about your top or bottom cat? I'm guessing your talking about the bottom since you want an exhuast. You shouldn't need it, they'll just have to add a bung for your second O2 sensor on the pipe after that area. Honestly you're not going to see any gains from removing it, I would just recommend getting a high flow cat for down there to help gaurantee that your second O2 sensor receives the correct readings and maintain legal emissions. Of course you could just have them make a delete pipe for you that way you can add a cat later to pass emissions and then remove it again easily. They have to add that bung for the sensor after that section anyway.
post Jun 24, 2008 - 7:30 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
I think it depends on what size piping you are getting as well. For example, if you get a 3" pipe, I don't think they will be able to use your old cat because the inlet/outlet is alot smaller. You of course dont have to have one though. Just keep in mind that if your state is strict like mine (california) you will never pass smog with anything other than what is already there.
post Jun 24, 2008 - 7:58 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Unless you have a turbo, 3" is a little overkill.
post Jun 24, 2008 - 8:42 PM
Legit94GT
Joined Feb 6, '08
From Oregon
Well i am planning on running 2.25 pipes...
So basically what i am gathering that if i do get a new one it should be a high flow cat?
What would be the gain to not having a cat? It seems like alot of work to deal with to not have one...
1 JL 1,000/1v2
2 JL 12" W6v2
post Jun 24, 2008 - 9:52 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Honestly there have been several magazine articles and the last I read they did a test on an Integra, and the most they could gather was 1hp more over a high flow cat if you go without. So given that it's only 1hp difference you might as well be smog legal.
post Jun 25, 2008 - 12:42 AM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE (GTS13 @ Jun 24, 2008 - 10:52 PM) *
true story:) thanks alot
1 JL 1,000/1v2
2 JL 12" W6v2
post Jun 25, 2008 - 11:12 AM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
dont mean to rob the thread...but how much hp gain will their be with a high flow cat?
post Jun 28, 2008 - 2:25 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
QUOTE (Jdog1385 @ Jun 25, 2008 - 11:12 AM) *
You don't gain much, it's more of just a principle kinda thing. If you're going to put an exhaust on your car to increase exhaust flow, then you might as well take care of every component you can. You're trying to open as much as you can. From what I remember a high flow cat only opens about .7hp, like I said before, it's not much but you wanna do it right.
post Jun 28, 2008 - 2:38 PM
manphibian
Joined Oct 13, '06
From UK
Removing the cat makes more difference than 1 HP.
post Jun 28, 2008 - 3:44 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
The last time I saw someone ran without a cat, he shot fireballs out of his muffler. If your state doesn't require smog issues i say just for for a Test Pipe.
post Jun 29, 2008 - 12:41 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Ok, it didn't take me long to find and I recommend everyone take a look at this good read*. What I've been trying to say, and I admit I may have not worded it very well. The difference between a de-cat test pipe and an aftermarket cat is only 1hp. You'll see good gains from either one over stock. 1 extra hp just doesn't seem worth it to me, I don't want to have to change it out everytime I want to pass emissions. If my friends can pass with their SR 240s then I'm sure it's possible, it just depends on what state you live in and if you're willing to put up with the possible headache.
*http://www.importtuner.com/tech/impp_0610_...ters/index.html
This post has been edited by GTS13: Jun 29, 2008 - 12:58 PM
post Jun 29, 2008 - 3:46 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
And there's another consideration -- you do breathe, right?
Lo-Fi Version Time is now: January 10th, 2025 - 11:36 AM
