![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) ![]() |
so awhile ago i saw this post from coomer about using st185 rear disc brake setup on his car...heres the link
http://www.6gc.net/forums/index.php?showtopic=45705 coomer writes... Rear Setup Stock AT200 spindles/hubs OEM ST185 backing plates OEM ST185 internal e-brake components OEM ST185 e-brake cables OEM ST185 single-piston calipers Satisfied ST185 ceramic brake pads Brembo ST204 OEM-replacement rotors (part number 25162 I think...may have been 25163) OEM AT200 front brake lines so since i couldnt get the st204 rear disc brake conversion stuff for the life of me...(with 3 failed attempts with members on this board ![]() ![]() does anyone have the part numbers for the st185 calipers, st204 calipers, st185 backing plate, and st204 backing plate? also the st184 backing plate and calipers as well. does anyone know if the bolt placements are at the same spots with the st185 calipers and st204 calipers??? id like to see if i can just pick up an st184 or st204 backing plate and if my st185 calipers would work with 'em. thnx in advance! -bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Lo-Fi Version | Time is now: February 21st, 2025 - 11:55 AM |
