30 Pages V  « < 22 23 24 25 26 > »
> Rusty's SS-II progress thread, Many TRD goodies
post Nov 8, 2013 - 2:32 AM
Rusty
Joined Nov 5, '07
From New Zealand
Yes he did comment about how good my lambda readings were, did you have any readings when you got yours tuned?
Not sure didn't ask, remember the toms ecu is the factory ecu with my guess a new daughterboard to allow them to adjust things (like what nistune up your way do) so since it uses the factory ecu case there is no extra aux points to plug into.
Haven't checked the diagnostic port, but wouldn't see why it wouldn't work. ACIS still operates, although when it switches over and closes higher rpm I'm sure it sounds more aggressive.
Rotor, cap and sparkplugs where recently changed anyway, still low km's remember wink.gif
I don't think it would be running 'on-the-edge' just they would have tidied up the super safe tune Toyota did.
post Nov 8, 2013 - 5:07 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Ahh, when mine was tuned there was every piece of data all logged by the dyno but i only got power and boost curve printouts unfortunately, i wish i had of gotten the AFR readouts now.
But i can tell you based on my wideband gauge that I have 14.7 at the tip of the pedal dropping to 13,12,11 when i step on it hanging around 11 onboost, dropping to as low as 10.5 at the very highest load points like 20psi and high revs
Mike W
269awhp / 273ft-lbs
post Nov 8, 2013 - 5:38 PM
Rusty
Joined Nov 5, '07
From New Zealand
Yeah, also side note I'm only going to run BP98, the 95 are inconsistent sometimes 93, 94 hence why they were changed to Vpower and premium etc. Gull's E85 was a joke anyway they've removed the ethanol out of it as it ruined the fuel stations pumps, lines etc
I think I'm pretty spot on with regarding a new daughterboard being installed. Though not 100% sure yet how Tom's did the adjusting/setting up, if it was via the diagnostic port or if they remove the ecu each time and plug it in to make changes that way.
Haven't seen a good photo of an opened ecu, but came across this in a stroke of luck on a youtube video. (I don't intend to open mine at all)
post Nov 9, 2013 - 2:59 AM
onnaj
Joined Sep 6, '12
From Holland
I won't be too worried about knocking. Even on 95 it should be okay with a stock compression of 10,3:1. My Blacktop with a 11,0:1 compression runs fine on 98 without knocking with an advanced timing of 10 BTDC.
So IMO you shouldn't be too worried.
post Dec 4, 2013 - 12:44 AM
Rusty
Joined Nov 5, '07
From New Zealand
^ Yeah just a personal preference really.
I came across this recently from MRP who were taking apart a TRD LSD like mine.
post Dec 20, 2013 - 3:50 AM
Wrcgt4
Joined Dec 19, '13
From Colac , Australia
Best FWD 6th gen in the world IMHO
Well done Rusty ! good to see it still going strong , and the passion to keep going still aflame smile.gif
post Dec 20, 2013 - 3:41 PM
Rusty
Joined Nov 5, '07
From New Zealand
ha cheers mate
post Jan 7, 2014 - 4:07 AM
Rusty
Joined Nov 5, '07
From New Zealand
Cleaned the engine bay this evening.
post Jan 7, 2014 - 4:10 AM
richee3
Joined Jun 29, '08
From Denver
Did you ever refurbish your TRD strut bar or is it naturally that clean?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 7, 2014 - 4:17 AM
Rusty
Joined Nov 5, '07
From New Zealand
I bought it brand new, and its naturally that clean.
post Jan 7, 2014 - 4:33 AM
richee3
Joined Jun 29, '08
From Denver
Very nice. thumbsup.gif Most of them I see, my own included, have a touch of surface rust. It just goes to show the amount of care you put into your car.
1998 Celica GT-
BEAMS Swapped.
post Jan 9, 2014 - 6:21 PM
Rusty
Joined Nov 5, '07
From New Zealand
cheers
Building up a list of maintenance parts to perform this year
post Jan 20, 2014 - 9:13 PM
Rusty
Joined Nov 5, '07
From New Zealand
So it's my birthday late next month, and wanting to get it ready for the end of march. Here's the list of parts I'm going to be ordering...
Drivetrain
✓ Clutch cover - 31210-ST851
✓ Clutch disc - 31250-ST852
✓ Clutch release bearing - 31230-32060 x Japan
✓ Flywheel bolts (8 bolts) - 90105-12187
Lighten factory flywheel & balanced. * Local company
✓ TRD LSD (install)
ATF fluid and a friction modifier, to suit the mechanical LSD and that doesn’t destroy the synchros. Managed to source TRD FF LSD Oil
✓ Gearbox Gasket kit - 04331-32011 x Japan
Shifter Bushing (1) - 33557-33010
Shifter Bushings (2) - 90386-12022
✓ Diff bearings L & R
Engine
✓ Radiator top cover - 16441-7A070 x Japan
✓ Radiator Gasket - 16462-42240 x Japan
✓ Gasket valve cover head outer -11213-88460
✓ Gasket valve head inner - 11214-88460
✓ Gasket ACIS manifold - 17315-88460
✓ Gasket TB - 22271-88461
✓ Engine Bay Gold Heat Reflective tape - MRP
✓ Front engine mount
✓ Rear engine mount
Oil catch can * Not 100% certain
✓ Red engine spray paint enamel - Valve cover
✓ Silver engine spray paint - ACIS Intake
✓ Clear engine paint
✓ Put on new engine sticker
Brakes & Wheels
✓ Front rotor (2) - 43512-20600
✓ EBC Red front pads - DP3995C *Low dust. because white wheels
✓ Rear rotors (2) - 42431-20360 x Japan
✓ Rear pads *
Wheel spacers.... 25mm?
Twin pot front brakes install * Going to require longer S/S lines, but its proving difficult to find: (SS-II SS 94-95 or SS-III 96-99 or SS-II 98-99)
✓ = Have the parts
This post has been edited by Rusty: Feb 20, 2014 - 5:33 PM
post Jan 21, 2014 - 7:32 AM
Are you ordering all of that OEM? Half the value of the car there.
post Jan 21, 2014 - 7:34 AM
onnaj
Joined Sep 6, '12
From Holland
Wow that's a lot to do!
You're well maintaining the car! Like to see that!
post Jan 21, 2014 - 3:49 PM
Rusty
Joined Nov 5, '07
From New Zealand
Yes I am, although there are a couple of parts there not just Toyota wink.gif
Cheers, hopeful it all comes along smoothly. Looking forward to painting those engine bay bits and white rims again... black pads lol
post Feb 20, 2014 - 5:41 PM
Rusty
Joined Nov 5, '07
From New Zealand
Recently got this
Just received today the main parts I was waiting on from Toyota, A day early birthday present smile.gif. As requested by 2 members I also ordered new splash guards, so they'll be getting those shortly once I send them off. Also got some front splitters for my brother's Allex ZZE123 (Corolla)
The brake rotors & rear pads I didn't get off Toyota due to price, went with another brand.
post Feb 21, 2014 - 2:31 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
you remind me of the guy from the beams forum he uses every little single bolts and nuts that is Toyota on his car. I'm talking about the guy who made the custom supercharger for the beams engine.
But nice stuff
post Feb 21, 2014 - 4:02 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
This got to be the number one 6gc. Lol.
post Feb 22, 2014 - 9:35 PM
Rusty
Joined Nov 5, '07
From New Zealand
Cheers guys
A rough job list:
Send out splash guards
Remove gearbox & radiator.
Install new lsd & replace bearings, flywheel lightened & balanced & new top cover on radiator.
motor mounts, flywheel, clutch, gearbox & radiator reinstalled.
1st intake manifold off & valve cover off paint, apply heat reflective tape
(Painting the intake manifold a silver & the valve cover is going anodised red)
Reinstall valve cover & intake
Rotors & pads replaced
Beer
Lo-Fi Version Time is now: February 18th, 2025 - 6:46 AM
