> What do you guys think about this EBC?
post Jun 28, 2008 - 8:21 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
http://cgi.ebay.com/ebaymotors/HDi-WRX-Ele...emZ330247502989
It looks like it will do the job and is realy cheap. Am I better off with a MBC instead?
94 Celica gt white (sold)
post Jun 29, 2008 - 8:55 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (bccentaur3 @ Jun 28, 2008 - 8:21 PM) *
I understand that its for a wrx, but why wouldn't it work on a 3sgte?
post Jun 29, 2008 - 11:38 PM
southwest2118
Joined Jan 13, '06
QUOTE (bccentaur3 @ Jun 29, 2008 - 8:55 PM) *
wrxs are four wheel drive dude and most celicas are two wheel drive ....thus the boost controller will crash when it doesn't see a rear differential
post Jun 30, 2008 - 1:02 PM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
QUOTE (southwest2118 @ Jun 29, 2008 - 11:38 PM) *
The differential has nothing to do with it. The reason why it might be application specific is that the plug is plug and play with the stock wiring.
post Jun 30, 2008 - 2:54 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Thank you^.
Southwest, I hope you don't think I'm that stupid. I did my research on this certain ebc and only wrx guys use them. If you go on to the companies website they talk about how it wires right up to the wrx harness.
I'm stuck on one thing. Will they offer a wiring diagram for all types of cars, or is it just wrx specific?
I tried googling it and it seems like the skyline guys use them, but I don't think its this same exact type ebc.
post Jun 30, 2008 - 3:16 PM
GTSOwner
Joined Sep 28, '06
Worse comes to worse, just wire everything up manually. If they supply a wiring diagram, it should be easy enough.
post Jun 30, 2008 - 3:18 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
The thing is, I won't know which wire goes where. I can wire up a safc all day long. But can I do it with an electronic boost controller? Not sure.
post Jun 30, 2008 - 5:10 PM
GTSOwner
Joined Sep 28, '06
How complicated can it be? I mean, I've never installed an EBC but what makes sense to me that would be there is : constant 12v, switched 12v, ground, signal (goes to the solenoid, so no wiring to factory harness), MAYBE illumination.
If you can install an SAFC, this is *probably* a piece of cake for you wiring wise.
post Jun 30, 2008 - 5:44 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yeah, I looked more into it and its the basic. 12v power, ground signal. Really nothing into the ecu, but this other one cost more. Same company and boost controller but diff. because its not wrx specific.
Lo-Fi Version Time is now: December 3rd, 2024 - 2:00 AM
