> ct26 coolant lines
post Jun 29, 2008 - 10:14 AM
JDcelica
Joined Jan 11, '07
From Rochester, NY
is it posible to use the coolant line from the throttle body to feed the turbo?
[img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
post Jun 29, 2008 - 10:23 AM
yes.
post Jun 29, 2008 - 11:14 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yes thats where almost everyone taps into.
94 Celica gt white (sold)
post Jun 29, 2008 - 3:30 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
thanks for the info. trying to finish the whole thing. only have two things left. i will post pics
post Jun 29, 2008 - 3:32 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Yeah, I'd love to see how you did it. WHen are you going to get it tuned?
post Jun 29, 2008 - 10:27 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
post Jun 29, 2008 - 10:30 PM
CelicaST_CALI
Joined Feb 28, '07
have u check ur oil lines??where is it coming from?
This post has been edited by CelicaST_CALI: Jun 29, 2008 - 10:30 PM
BANNED. for life, you moron.
post Jun 29, 2008 - 10:33 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
did you clamp on the oil drain hose to the oil pan union? Did you make sure your dip stick is on all the way. I was an idiot and when I installed everything I didn't notice the oil dipstick was out of the tube a little and oil was squirting all over the place.
post Jun 30, 2008 - 7:29 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
its coming out of the back of the engine. i rtv ed the pan twice and is still leaking now it comes out in a steady stream with the car not runing
post Jun 30, 2008 - 8:24 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Did you let the car sit and let the rtv dry? btw rtv won't work as well as the toyota gasket stuff. I had the same leaking problem so I went out and got an oil pan gasket from napa and added gasket maker with that.
post Jun 30, 2008 - 8:27 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
did yours drool out not started
post Jun 30, 2008 - 8:40 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Heck no...
post Jul 4, 2008 - 9:50 AM
forget the RTV, that stuff is crap compared to the OEM toyota FIPG (Form In Place Gasket)
hit your local dealer, buy a tube.
make sure the mating surfaces are CLEAN!!!!!
follow the BGB instructions for reinstallation of the oil pan, and you should have no issues.
post Jul 4, 2008 - 11:47 AM
JDcelica
Joined Jan 11, '07
From Rochester, NY
thanks got a cork gasket and put it on and im pretty sure it stopped the leak. but i cant figer out a new one i have sprung.
Lo-Fi Version Time is now: December 3rd, 2024 - 9:11 PM
