Door Shell |
Door Shell |
Jun 30, 2008 - 7:43 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
Could I use a door shell from a car that doesnt have power windows?tnx
-------------------- God made man....
Everything else... Made in China |
Jun 30, 2008 - 7:54 PM |
Could I use a door shell from a car that doesnt have power windows?tnx the best one to answer this would be griffg. I dont see why not, there is no reason toyota would have made diferrent shells, all you plug in is the accesories.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jun 30, 2008 - 8:20 PM |
Enthusiast Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
more than likely...I've seen the inside of both...they look the same.
Jul 1, 2008 - 8:57 AM |
Just plug and play right? no other extra components except that it the door came from a car w/ manual windows.
Jul 1, 2008 - 9:11 AM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
yeah, you just wouldn't Plug in the Power Window's wiring. Just make sure it's taped off, even if it is in a harness. Just incase
This post has been edited by D-Man: Jul 1, 2008 - 9:11 AM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Jul 2, 2008 - 1:43 PM |
The answer is yes, mostly. It'll be a slight PITA, but not too terrible and definitely do-able.
All the window stuff, power or manual, bolts in to the inside shell (not to be confused with the door panel). Actually, now that I think about it, the mechanism for the locks (power or manual) bolts onto the shell and the side panel (the part where the door latches). You'll need to swap out the door lock actuator from your car to the new shell. It's pretty easy to do though - there's 3 screws on the side panel, just above the latch, that bolt in the door lock stuff. I'll be completing my window conversion this weekend, so if you can hold off 'till Monday if you need pix, I should be posting up photos by then. -------------------- |
Lo-Fi Version | Time is now: December 1st, 2024 - 9:15 PM |
