> do i need a camber kit with a drop more then 1.5 ", constantly changing tires
post Sep 11, 2003 - 2:54 PM
chaznad
Joined Sep 10, '03
From houston
hi , i just got my celica back after 4 years ,anyways when i had it back then i had it lowered with intrax springs( i think about 1.7-1.8 " drop) DIDNT REPLACE STRUTS SHOCKS, OR GET A CAMBER KIT !!!!
the problem was i was young and stupid and i didnt know i had to get an alignment after the spring install, idiot installer didnt even tell me.
lets just say after 5 months i started going through tires like every 2 months , im thinking thats coz of no alignment after install ??????? is it???
ok i wanna drop it again w/ intrax springs
have any of you guys had this problem EVEN AFTER getting an alignment w/ no cambers??????or is it just coz i got no alignment????
how often do you guyz change your tires with an alignment ?
also the car has 84000 miles on it , i plan on driving it lightly and it was driven lightly before do i need to replace the shocks on it or will it hold up on me, also how do i know the shocks have gone bad,, will i hear a noise or something
post Sep 11, 2003 - 6:27 PM
3TST
Joined Sep 27, '02
From UK
Normally you would only need a camber kit if you lower 2" or more or have coilovers.
So the cause of the problem is most likely the alignment.
As for the shocks, with 84000+ miles, you probably wont here any noises but its advisable to change them if your lowering again.
Lo-Fi Version Time is now: February 21st, 2025 - 9:28 AM
