Low rpm missfire |
Low rpm missfire |
Jul 8, 2008 - 11:04 PM |
Enthusiast Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
So, i have this very low missfire/thump at around 1200 rpms, but if i play with the tps i can almost change the location of this missfire/thump, its very werid, and i believe it affects driving throughout the rpm range Parts i have changed out. Plugs Wires Cap+Rotor Fuel Filter TPS anyone have any ideas/methods of testing things? when the tps is disconnected it misses alot more |
Jul 8, 2008 - 11:12 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
change teh O2
Jul 9, 2008 - 1:25 AM |
o2 seems to be in check, goes into loop at idle, and open when driving, i don't believe its the o2
Jul 10, 2008 - 1:25 PM |
anyone else got a clue? i did a boost leak down test, set timing..
Jul 10, 2008 - 2:14 PM |
what bov are you using?
have you tried... 1. setting your tps to its factory position? 2. changing your cap/rotor/wires/plugs? 3. a new coil? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 10, 2008 - 5:21 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
meh....check compression, bad ringland will cause this....did it to me anyway...
Jul 10, 2008 - 8:36 PM |
tps is new, and is set to factory position, brand new spark plugs, and wires, cap and rotor have about 2k on them, waiting on a coil, the one that is in there did pass the test, compression is 180 across the boards, using a hks ssqv(has given me no problems)
also when driving and light throttle is applied/vac is between 20-10 it kinda bucks/thumps, but when i give it some more gas it seems to go away, but i believe myself that its the igintion, and i doubt its my ignitor since it doesn't follow in those symptoms, hopefully the coil will do it I do pull off 21vac at idle, but when my car is around 2k on the dev rev it gets really low like 25-26 while it pops, lol This post has been edited by supra12big: Jul 11, 2008 - 2:04 PM |
Jul 15, 2008 - 9:57 PM |
anyone????
Lo-Fi Version | Time is now: January 10th, 2025 - 11:51 AM |
