For welding, any good websites. Im planning on buying those torches from home depot that are refillable and stuff, does not seem like a tough thing to do.
Im doing a seat swap for my celi But Fiberglass, where can i get supplies, tips and tricks. I need to fix my new trd bumper. I dont want to take it to a chop shop, i want to learn. Any ideas pointers, and websites are helpful This is what i need to fix... ![]() -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) ![]() |
what do you want to know about FG?
EDIT: what are you doing with FG rather. It can be purchased at any lowes / home depot or specialty stores. But depending on what you're doing, you may need a special Chem-Resin. there are basically 5 types of resin. What are you doing and i'll help you decide what is best for your purposes. This post has been edited by D-Man: Jul 9, 2008 - 10:04 AM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) ![]() |
i thought that the kit would be made of poly since it's a toyota kit vs aftermarket. are you sure it's FG? wish i knew more about what you need but i don't. either way can't wait to see it on the car.
if you are talking about fixing that little bit of chipping around that point, you aren't going to need to fiberglass that.
sanding + some spot putty/body putty is what will fix that. but like Dman said, we need more information on what you are going to attempt to do with fiberglass to give accurate information. This post has been edited by playr158: Jul 9, 2008 - 11:41 AM |
if you are talking about fixing that little bit of chipping around that point, you aren't going to need to fiberglass that. sanding + some spot putty/body putty is what will fix that. but like Dman said, we need more information on what you are going to attempt to do with fiberglass to give accurate information. well its not just a chip, the trd bumper is fiberglss, the pic above is just one of the corners that is cut of from the corner, its missing about .75 of a cm. also it has a big gash underneath that needs to be sealed. and supported. basically i need to know how to fix the bumper imperfections. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Enthusiast ![]() Joined Jun 26, '08 Currently Offline Reputation: 1 (100%) ![]() |
what are you going to be doing with welding? custom seat bracket?
for that i would suggest using a MIG or TIG welder... TIG is gonna be alot tougher and you should only do that if you know what your doing, if you have no welding experience its a no go! mig is fairly straight forward, once you know how to set the welder. I wouldn't do OA(oxy-acetylene) gas welding either, kinda on the level of TIG and its quite easy to f it up.. really the only way to learn how to weld is to weld, get some scrap metal and just start laying down beads with any decent welder. i can go into more detail if you need help figuring out anything. |
i can go into more detail if you need help figuring out anything. wha is mig tig, pig fig lol ![]() Home depot sells some home welding kits that look like a torch, i was planning on doing that. is that ok? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
MIG(GMAW)- gas metal arc welding... http://www.thefabricator.com/ArcWelding/Ar...icle.cfm?ID=929 thats a decent article explaining the basics (i think, i didnt read it lol)
TIG- tungsten inert gas welding... i wouldn't even try it, but if you want to: http://www.millerwelds.com/education/tech_tips/TIG_tips/ OA- oxy-acetylene... the torches you see at home depot, takes a while to get the hang of: http://www.stanford.edu/group/prl/documents/html/OAweld.htm ARC(SMAW)- shielded metal arc welding... also called rod or stick welding. http://en.wikipedia.org/wiki/Arc_welding that should tell you everything you need to know about the basic welding... another site to check out is http://www.weldingengineer.com/ and to get welding equipment: the best equipment is gonna come from a welding supply store and costs a pretty penny. My welding gloves cost 50 bucks a pair, but they keep my hands cool and have enough dexterity to allow me to tig weld. to get cheap equipment goto any hardware store or harbor freight tools. the welder i have in my garage is from harbor freight and cost 100 bucks(not including wire) and works for almost any project i can do at home.... except for a... well you dont need to know about the project i f'd up hehehe just to give you a comparison.. the welder i learned how to weld on, about the quality you would see in a top welding shop, cost about 4 grand and was extremely nice! I This post has been edited by aflacattack: Jul 9, 2008 - 8:03 PM |
got it. so guess better off paying to be done. Hmmm, let me read those articles
you could do it yourself, but just make sure you do some practice welds before doing the final one you know?
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:43 PM |
