> Oil Pressure Gauge Wiring, Part II, Blew a fuse...
post Jul 9, 2008 - 9:13 PM
jophish
Joined Jul 6, '08
From Burlington, VT
Well i got my gauge all wired up and looking great, spliced into the dimmer circuit and everything. However, when i plugged everything back in , i blew the "panel" fuse in the box. Any advice as to what i should do now, besides get a new fuse...should i buy one with a greater (wattage? amperage? i dunno what the numbers indicate) or should i just get another 7.5?
post Jul 9, 2008 - 9:21 PM
parriehunter
Joined Jan 13, '08
From Christchurch New Zealand
QUOTE (jophish @ Jul 9, 2008 - 9:13 PM) *
Don't go higher. Get another 7.5Amp fuse. If it blows again check you haven't created a short or anything like that.
post Jul 10, 2008 - 3:41 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
likely the splice has created a short, just check the wires and use only the 7.5 amp fuse, thats what the wires that are ran can handle
post Jul 12, 2008 - 3:57 AM
Deezz_Nuttz
Joined Feb 26, '06
From CA
ground?
'99 GT & '06 GTI
post Jul 12, 2008 - 3:32 PM
jophish
Joined Jul 6, '08
From Burlington, VT
got it all sorted out...turns out when i spliced the wires in i didn't tape off all the exposed copper, and when the touched it caused a short...it was a 15 minute fix. thanks a bunch
Lo-Fi Version Time is now: November 27th, 2024 - 5:23 AM
