> Hooking up my alarm to my window, got problems, So i tried connecting my alarm to my window...
post Jul 11, 2008 - 3:15 PM
Ugglan
Joined Jan 8, '08
From Sweden
So I want to connect my alarm to my driver side window so that the window roll up when i lock the doors. My alarm has an output that generates 0.65V for about 13 seconds. So that is all good, exept that it is ONLY 0.65V.
I was going to connect it to a relay (spelling?) but the relay triggers first at 9V...
I know how to use my multimeter so I'm pretty sure about the voltage (also tryed the relay but it is silent, should klick).
So, anyone got any ideas what to do?
//Johan
post Jul 12, 2008 - 5:00 AM
Hanyo
Joined Aug 16, '03
From Bay area
Hi i have done the same window roll up set up your trying to do.
If your trying to hook up the roll up module to the locking signal on your remote, it will not work. Because the signal from your alarm is only a pulse (maybe half a second of signal) and that is not enough to roll up the entire window. What you would need to do is hook up the roll up module to your "armed when ground" wire on your alarm.
The "ground when armed" wire is usually the same wire you use for kill start.
good luck.
post Jul 14, 2008 - 2:39 AM
Ugglan
Joined Jan 8, '08
From Sweden
QUOTE (Hanyo @ Jul 12, 2008 - 5:00 AM) *
good luck.
So no, I'm not trying to connect my window module to my locking signal. But tanks anyway.
I think i must messure the output again, 0,65V does not sound right at all...somthing must be wrong...
Lo-Fi Version Time is now: February 22nd, 2025 - 4:12 PM
