> Removeing charge cooler
post Jul 13, 2008 - 5:57 AM
darranst205
Joined Jun 8, '08
From kerry ireland
hey has anyone here removed the charge cooler off a st205 (3s-gte)for a fmic if so how do u bypass the ecu fault code to stop it cutting to safe home mode can u trick the ecu into thanking the charge cooler is still there
post Jul 13, 2008 - 4:56 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
post Jul 13, 2008 - 5:03 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
If you have a basic understanding of wiring schematics that should be pretty easy to figure out. Basically there's a relay triggered by the INT signal of the ECU to send a signal to the M+, M-, and MTT pins of the ECU through a pair of 1k resistors. E represents the ECU's ground. Let me know if you need more help, I came up with this a year or two ago and it's been confirmed working by Urbandork and someone else on alltrac.net but I can't remember their name.
This post has been edited by WannabeGT4: Jul 13, 2008 - 5:04 PM
post Jul 14, 2008 - 6:20 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Since you already have everything there in your car, you can just replace the pump itself with a 1/2 watt or 1 watt 1k ohm resistor. The other parts shown in the schematic above are already in place in your car...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jul 14, 2008 - 6:59 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Actually you'll need a pair of 1k resistors wired like this:
I always assume it's a swap... I forget people are actually lucky enough to own a real ST205... jealous.
post Jul 22, 2008 - 1:44 PM
darranst205
Joined Jun 8, '08
From kerry ireland
QUOTE (WannabeGT4 @ Jul 14, 2008 - 7:59 PM) *
ur a life saver thank u so much
post Jul 22, 2008 - 2:13 PM
http://www.gtfours.co.uk/default.htm?http%...ow_to/dv/dv.htm
post Jul 23, 2008 - 1:18 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (Batman722 @ Jul 22, 2008 - 2:13 PM) *
Thanks DarkKnight wink.gif I couldn't find the site so I just posted the image I had saved on my comp. Credit where credit is due.
http://www.gt4dc.co.uk/info/howto/205_fmic...mic_code_54.htm
Lo-Fi Version Time is now: November 24th, 2024 - 2:21 PM
