![]() Enthusiast ![]() ![]() Joined Jan 4, '08 From Clearwater, Fl Currently Offline Reputation: 5 (100%) ![]() |
I want to get some side skirts for my celi but i am afraid about speed bumps etc. For those of you have have Tien S tech lowering springs and side skirts do you ever have problems?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
Celicas can be dropped pretty low with the exception of body kits.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
its the front and backs that have problems with bumps, but lowering it an inch to 1 1/2 shouldnt be bad with skirts
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
NO PROBLEM!!!!!!!!! I WANT TO GO LOWER!!!!!!!!! GO 2" GO!!!!!!!!
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Yeah it doesent seem like the sides are a problem but i hit a bad speed but a couple weeks ago and hit my crossmember.
how fast you were going???? i didnt hit mines yet.
The first time i went over i was going fast for a speed bump. The next time i went by the same speed bump i went really slow and it happend again. Maybe just a wierd speed bump.
Anyone one had problems with invaders?they look a little bigger than other skirts.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) ![]() |
S-Techs and stock side skirts, no problems noted.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) ![]() |
stock or 404 have no problems. or shouldn't. still too high wanna go lower.
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Ok cool, i feel better about it now. I should get them in the next couple days..ill post a pic once i paint them and put them on.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
S-Techs and stock side skirts, no problems noted. Just also keep in mind wheel size effects his question... -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
S-Techs and stock side skirts, no problems noted. Just also keep in mind wheel size effects his question... Very true. If it helps, I was running stock wheels/tires, 18x8 w/215/35-18 tires (same overall diameter) and 18x8 w/225/40-18 tires (slightly larger than stock diameter), all with zero issues. -------------------- |
i have 17's.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) ![]() |
i have 16s (not sure of the tire specs though) and no problems with scraping. i have oem sides on mine. it will also depend on how good/stiff your struts are.
athorn dont worry much about it. if you scrape, you scrape. i scrape...........but that's on really inclined driveways and really high bumps.
Thanks for reasuring me everyone. New stuts and shocks are the next thing on my list.
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:43 AM |
