Alarm System |
Alarm System |
Jul 16, 2008 - 6:29 AM |
Enthusiast Joined Apr 10, '08 From Galloway, OH Currently Offline Reputation: 1 (100%) |
Hello all,
I've been meaning to ask if anyone know anything about alarm system wiring. I guess the previous owner broke his remote to his alarm so instead of getting a replacement remote he decided that he didn't want the alarm so he cut the wires. It didn't bother me, but now I noticed that my door light doesn't come one when I open my door and also the door ajar light doesn't come on when I open my door or if my door isn't close all the way. Does anyone know how I can go about looking to see where to reconnect the wires? I found 2 wires under the dash on the driver sided. I know one goes to the alarm under the hood b/c it has the same color, but I am not sure what the other wire is and what I need to reconnect to get my door lights to work. Any suggestion would be appriecate it. Thanks -Pong |
Jul 16, 2008 - 10:35 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
If the previou owner cut it, my guess is that he cut/disconnect the wires going to the door switch. Check those switches and see if they're still connected, if they are he might have sliced the wires from the plug. You said something abt the two wires found underthe dash? here is a wiring diadram:
QUOTE 1995 Celica
Item Wire Color Polarity Wire Location 12V White- Black/Red + Ignition Harness Starter Black/White + Ignition Harness Ignition Black/Orange + Ignition Harness Second Ignition Blue/Red + Ignition Harness Accessory Gray + Ignition Harness Power Lock Blue/Back - Lock Module right of column Power Unlock Blue and Green *1 - Lock Module right of column Parking Lights + Dk. Green At Dimmer Parking Lights - Lt. Green Steering Column Headlights Red/Black - Steering Column Door Trigger Red/White - Drivers Kick Panel *2 Trunk/Hatch Pin Red/Green - Drivers Kick Panel *2 Tachometer Gray Check Connector Brake Wire Green/White + Driver Kick Panel Horn Trigger Green - Steering Column LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down Grn/Wht - Red/Wht LR window switch RR Window up/down Green - Red RR window switch *1 Use both wires and diode isolate each. *2 Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape -------------------- 98% completion --- aaRon |
Jul 17, 2008 - 7:36 AM |
If the previou owner cut it, my guess is that he cut/disconnect the wires going to the door switch. Check those switches and see if they're still connected, if they are he might have sliced the wires from the plug. You said something abt the two wires found underthe dash? here is a wiring diadram: QUOTE 1995 Celica Item Wire Color Polarity Wire Location 12V White- Black/Red + Ignition Harness Starter Black/White + Ignition Harness Ignition Black/Orange + Ignition Harness Second Ignition Blue/Red + Ignition Harness Accessory Gray + Ignition Harness Power Lock Blue/Back - Lock Module right of column Power Unlock Blue and Green *1 - Lock Module right of column Parking Lights + Dk. Green At Dimmer Parking Lights - Lt. Green Steering Column Headlights Red/Black - Steering Column Door Trigger Red/White - Drivers Kick Panel *2 Trunk/Hatch Pin Red/Green - Drivers Kick Panel *2 Tachometer Gray Check Connector Brake Wire Green/White + Driver Kick Panel Horn Trigger Green - Steering Column LF Window up/down Green - Red Drivers Door Switch RF Window up/down Grn/Wht - Red/Blu Driver Kick Panel LR Window up/down Grn/Wht - Red/Wht LR window switch RR Window up/down Green - Red RR window switch *1 Use both wires and diode isolate each. *2 Door and trunk trigger looped out of main harness heading towards rear of car, almost directly below door hinge wrapped in beige tape Where are the switches? I took the dash off to see where the wires are connected to, but can't seem to tell. One of the wires have 2 black and red connected to each other. The other wire is black w/red strip. Then while looking around I found a black wire as well. I also notice toward the back there is a harness that's not connected to anything, but I can't find where it might connect to. Thanks -Pong |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:01 PM |
