![]() Enthusiast ![]() Joined Oct 5, '05 From Milwaukee Currently Offline Reputation: 1 (100%) ![]() |
I believe my master cylinder is takin a **** on me. I bought a brand new one from 95celgt. HOwever, the one that he shipped me has a line connection on the opposite side....I assume that it's the wrong part al together? or did Toyota modify it or sumthin. It does look all the same except that part of it. It sux, any body got any suggestions? My brake pedal is SUPER soft. It does not go all the way to the floor, but damn near. I see no leak of fluid under the car......help me out brothas!!
Enthusiast ![]() Joined Jun 11, '08 From Clifton Park Currently Offline Reputation: 0 (0%) ![]() |
That could be a few things... check your calipers or drums if you have them... the bleeders may be either rotted off and are leaking, or they could be lose and letting air into the brake lines... try to bleed them... make sure all of them are tight though.... or it could be the master cyl.. i had that go on my prelude... and a contour
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
Bleed the brakes all around. It's probably air in the line.
Lo-Fi Version | Time is now: February 20th, 2025 - 12:54 AM |
