> Changing Cigarette Lighter Bulb to LED, I think i need a resistor...
post Jul 17, 2008 - 4:44 PM
jophish
Joined Jul 6, '08
From Burlington, VT
So i've removed the bulb from the little mount thing without any hassle, but when i've gone to test which way i should put the LED, I find that it will only light up for a few seconds before i goes dim and eventually dies...i've killed two LED's this way just to make sure that the first one wasn't faulty, and my best guess as to the solution is that i need to put a resistor in there with the LED. Anybody done this before?
-Joe
post Jul 17, 2008 - 4:59 PM
stevest202
Joined Oct 28, '07
From epworth uk
you need the resistor for that one or buy a pre wired led/resistor thats what i did but ive taken it out now for start button
a pic when it was in
post Jul 22, 2008 - 11:47 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
yes you do need a resistor. put two or three leds in so that it shines evenly all around. i did with mine, a friend help me out.
post May 22, 2009 - 6:16 AM
r1chie
Joined May 14, '09
From Sydney, NSW
im having problems with this. can any1 help ive tried removing the bulb with no luck too. any tips for that
also does this take a 3mm led or does it take 74 led? ive read on other posts that it takes a 74? can sum1 clarify
post May 22, 2009 - 11:11 PM
solidxsnake
Joined Apr 20, '09
It takes something smaller than a 74 I believe, mine seemed much smaller than a 74 at least. The bulb also was not removable from it's base, it had a plastic twist-lock base, I believe.
~Moving on to a 2002 Corolla S~
R.I.P Tom Celica - 1994-2010
post Jun 3, 2009 - 7:23 AM
putting an led there is a fire hazzard. i took mine of, plastic melts, and burns pretty quick
post Jun 3, 2009 - 10:21 AM
AnaXyd
Joined Jul 15, '08
From Norway
Why fire hazard? A tiny led cant be that dangerous? And if it gets too much voltage, it just dont work anymore.
post Jun 3, 2009 - 10:54 AM
if you smoke and if you use lighter, the heat from the lighter can cause the led to heat and melt.
not exactly something ill risk my celi for. Now if you are going to use it for chargers, no biggie.
post Jun 3, 2009 - 11:41 AM
AnaXyd
Joined Jul 15, '08
From Norway
Hmm, why would the led melt when its hotter?
post Jun 3, 2009 - 1:52 PM
have you tried to put a plastic tab next to the red hot lighter. It kind of melts. The LED is not made to stand those temps.
post Jun 3, 2009 - 5:17 PM
AnaXyd
Joined Jul 15, '08
From Norway
Lo-Fi Version Time is now: November 23rd, 2024 - 12:49 PM
