> jdm sidemarkers, help
post Jul 18, 2008 - 2:13 AM
junost4
Joined Aug 15, '06
From moreno valley
i want to put jdm sidemarkers on my st celica...but i want them to blink and stay on when i turn on my lights...where do i have to splice the wires to..i tryed the front side marker but its etiter blink or stay on...
post Jul 18, 2008 - 9:21 AM
azian_advanced
Joined Apr 18, '05
From Calgary
follow this how-to to make them blink with your turn signals
http://www.6gc.net/howto/install_jdm_sidemarkers
9. Remove the front turn signal and locate the wires you would like to splice the side marker into. NOTE: the negative from the side marker must go to the white/black stripe wire on the parking light. If you want the side marker to be on constantly, then you should wire the positive into the solid green wire, but if you would like for the side marker to stay off, yet blink when your blinker is on, wire it into the green/yellow striped wire (you will see my connections in picture 4.)
post Jul 19, 2008 - 7:51 AM
Tech-Nics
Joined Jun 18, '08
Are they supposed to stay on and blink? Or are they are originally just for blinkers only?
post Jul 19, 2008 - 3:26 PM
azian_advanced
Joined Apr 18, '05
From Calgary
originally they're meant to stay on w/o blinking (parking lights) on the first click of the headlight stalk.. but they can be wired so they will turn on to blink with your turn signal and turn off afterwards.
Lo-Fi Version Time is now: November 26th, 2024 - 6:56 PM
