Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
any help would be great. bought some white and blue 3mm 5000mcd LED's to swap into the climate control and i need to know if i need some resistors.. Not sure but i do have some 1/4W 510ohm resistors around too. any help would be awesome!
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
![]() Enthusiast ![]() ![]() ![]() Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) ![]() |
if the leds are on the circuit board there straight swop but as for the illumination back lighting they need resistors
ok more details needed... i found the ones on the board, where are the others?
![]() Enthusiast ![]() Joined Mar 27, '08 From Fort Worth, TX Currently Offline Reputation: 1 (100%) ![]() |
here use this...
http://ourworld.compuserve.com/homepages/Bill_Bowden/led.htm It is a very useful tool also depending on how you are wiring it up, you could try these route. http://www.oznium.com/forum/topic20 -------------------- ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:23 PM |
