boosted 5sfe problem |
Jul 21, 2008 - 7:36 PM |
Enthusiast Joined Jul 15, '08 From Fort Wayne Currently Offline Reputation: 0 (0%) |
sup people i just got done boosting my 5sfe, i replaced the rods and pistons w/ afteramrket parts and it's built to handle the turbo. i'm having trouble keeping my head gasket from leaking. i've replaced it twice and its getting annoying. can anyone point me to a head gasket thats better then stock... i cant find any aftermarket ones for turbo....
Jul 21, 2008 - 9:15 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
did you get your head machined so it's flat?
Jul 21, 2008 - 10:39 PM |
is an OEM metal head gasket ?
Jul 22, 2008 - 1:11 PM |
yea everything was done right with the head and the block. i just cant find a head gasket made for boosted 5sfe. Only aftermarket one i could find was a metal one.
Jul 22, 2008 - 2:20 PM |
are you using a metal headgasket ? or an aftermarket one ?
toyota makes a mhg for the 98-99 5sfe. that's your best choice. -------------------- |
Jul 23, 2008 - 3:26 AM |
on my 3rd oem metal head gasket.
Jul 23, 2008 - 9:24 AM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
your head is probably warped. An oem metal headgasket should not leak like that. Did you have your head resurfaced while you were getting work done?
Jul 23, 2008 - 9:42 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Yeah definitely sounds like there's a problem with the head or the block not being perfectly flat, or the head is not being installed correctly. The stock head gasket should hold up no problem, that's not really a big problem spot on those engines.
That said, if you're running extremely high boost and you're still loosing the head gasket, you could o-ring the block. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jul 23, 2008 - 6:44 PM |
yea..... the shop ****ed up the head on it... wasnt assembled right (which they told me it was ready and done), and it was warped a bit (their fault) they took it apart today and they where shocked to see how bad it was. least their putting a new head on it for free.... so they say.
Lo-Fi Version | Time is now: November 24th, 2024 - 7:49 PM |
