My Project Headlight... Projectors+Angel Eyes+LED, Done with the project!! Thx Rayme 4 Clear lenses |
Oct 26, 2008 - 11:02 AM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
vincent how come you won't make copies of the lenses and sell them? Not sure Rayme is still making these though.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Oct 26, 2008 - 11:52 AM |
Enthusiast Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) |
vincent how come you won't make copies of the lenses and sell them? Not sure Rayme is still making these though. My pairs and my friend's (Black One) pair are using Rayme's Lenses... Can't say perfect, but nearly perfect in my eyes, I am satisfactory with that... How come you ask such question? I don't have skills for that... and don't wanna waste time to source... -------------------- |
Oct 26, 2008 - 12:47 PM |
well I wasn't sure if Rayme was still making them
Dec 19, 2008 - 11:03 AM |
My buddy's one, same component, but the ballast in Black and paint black
Dec 19, 2008 - 1:30 PM |
That looks really good - what did he use as a shroud? Did he custom make one, or did he have one for those projectors? I'm about | | <--- that close to doing a projector retrofit, and I'm still looking for the perfect material to make a shroud with.
Dec 19, 2008 - 1:47 PM |
Don't get it, what do u mean by shroud? U mean housing or what? Everything is stock, just need to drill holes to fix the projector ballast, and use spray paint to paint all the plastic pieces in Black
Dec 19, 2008 - 6:53 PM |
The shroud is the part that goes around the projector housing so it's not visible. Are those JDM projectors that were modified in that picture w/the black painted reflectors, or are they non-projector lights that were retrofitted with projectors?
Dec 19, 2008 - 8:21 PM |
The shroud is the part that goes around the projector housing so it's not visible. Are those JDM projectors that were modified in that picture w/the black painted reflectors, or are they non-projector lights that were retrofitted with projectors? ic, of course used non projector lights and retrofitted with a aftermarket projector ballast -------------------- |
Sep 29, 2009 - 6:41 PM |
Enthusiast Joined Sep 15, '03 From Germany Currently Offline Reputation: 0 (0%) |
Hello together, hello vince.
Today i started to retrofit some headlights. I got the glass off very easily. 120°C in a steam oven 5 Minutes and then just slightly use a knife or a palet knife or so. Then i took the headlights apart. No problem. I then started to dremel out the inner circle of the refelctor. see picture: then i tried to get it a little square... But now before i go further i have got a few questions. 1) How much should the projector itself look out on the backside of the reflector? 2) At the projector itself is there a left and a right one? They both look the same. 3) At the projector there is this metal plate which covers a part of the light. You know. But when the projector gets attached will this metal plate be on the upper site or on the bottom of the Projector? I gues on the upper site like this: Please answer to all questions. Thank you. Joerg This post has been edited by snakeloa: Sep 29, 2009 - 6:42 PM -------------------- |
Sep 29, 2009 - 6:50 PM |
Enthusiast Joined Jul 9, '09 From CT Currently Offline Reputation: 2 (100%) |
is it possible to get a pair of angel eyes/halo rings inside my low beams with out turning them into projectors? I just love the halo ring when it's lit and want them so bad!
Oct 1, 2009 - 10:04 AM |
Enthusiast Joined Feb 18, '09 From Costa Rica Currently Offline Reputation: 4 (100%) |
-------------------- 1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored |
Oct 1, 2009 - 11:46 AM |
1) How much should the projector itself look out on the backside of the reflector? I don't have spec for this, sorry 2) At the projector itself is there a left and a right one? They both look the same. Both are the same, no matter which one left and right, both are for left hand Drive, I mean the beam direction 3) At the projector there is this metal plate which covers a part of the light. You know. But when the projector gets attached will this metal plate be on the upper site or on the bottom of the Projector? I gues on the upper site like this: There is 2 wires out of the projector, hook it to any 12v source, u will see the motor make the metal plate flip down, and let the beam strike higher to serve as high beam So. should be sit at the buttom, try it before fix it mate -------------------- |
Oct 2, 2009 - 9:40 PM |
Enthusiast Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) |
not feeling it. i love the styling of the jdm ones already.
Oct 19, 2009 - 11:44 PM |
Enthusiast Joined Aug 19, '09 From Sydney Currently Offline Reputation: 0 (0%) |
Do you still make these?
Is there more pics? -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:56 PM |
