Rattling when clutch is not engaged, STILL NEED HELP GUYS!!!!!!!!!! |
Jul 25, 2008 - 4:11 PM |
Enthusiast Joined Nov 23, '07 From Houston TX Currently Offline Reputation: 0 (0%) |
Ok, ive got a rattle somewhere and its kinda worrying me and here is why.
I have this odd rattling sound, loud enough to make it over the engine noise, when my clutch is not engaged. When i engage the clutch it goes away. When im costing and out of gear i can hear the rattling and when im at a dead stop out of gear it rattles. When im rolling with it in gear no rattling, when im rolling with clutch engaged no rattling, when im at a dead stop with clutch in gear no rattling. Basically its only doing it when the car is out of gear and the clutch is not pushed down. Now. I just had the tranny reworked as some might know and i called the guys who did it (these guys came very well recommended by Star Toyota, a Tech friend of mine, and believe me when i say that they replaced everything that was a problem or was going to be a problem any time soon), i even got a new clutch. Nothing is pulling in the tranny, it shifts smooth, no grind, no noise, no shacking.... nothing. Now things that you need to know. My cars CVs are Sh!t! they are very out and need to be replaced. They got worse after the guys fixed the tranny but they were bad anyways and i figured them pulling them out and jerking them around to get the tranny out, finished the job and now they are just toast. I have new ones and will be replacing them Tuesday. Could this be causing the rattling? When i say they are bad, i mean, When i turn they pop and when i get past 3000 RPMs they make this really nasty grinding noise. I dont Believe any of this stuff has to do with the tranny because all gears shift fine, pedal is tight, and no leaks. But this rattle has got me stumped. I was going to see if i can get someone to press the clutch down and see if i can track the noise but i wanted to see if anyone had any ideas. Thanks everyone. This post has been edited by Havok1997GT: Aug 7, 2008 - 5:26 PM |
Jul 25, 2008 - 4:17 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
This is a common thing that has been discussed here many times. Unfortuanetly I wasn't one of the people with the problem so I didn't really pay attn to what the fix was [Plus you know I don't do tranny's except to replace them]. Hopefully someone will be along to help here soon.
-------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Jul 25, 2008 - 4:53 PM |
A friend told me he thought it could be the Throw Out Bearing. Could this be the case?
Jul 25, 2008 - 4:54 PM |
Yeah - Sounds right but I'm not the one to ask
Jul 25, 2008 - 5:12 PM |
For the sake of saying so. Say that is what the problem is. where is it? outside or inside the tranny?
Jul 25, 2008 - 5:15 PM |
Enthusiast Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) |
On the shaft that goes through the clutch and flywheel. Inside the bellhousing.
-------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Jul 25, 2008 - 5:21 PM |
Jul 25, 2008 - 5:23 PM |
You'll hear it and possibly feel it if you rest your foot on the cluth pedal lightly.
Jul 25, 2008 - 5:27 PM |
I have had the same noise for a few years now. Its mostly caused by the throw out bearing or something with the clutch assembly. It seems to be a very common issue, but never causes any problems for anyone.
What brand/type clutch is it? Get your axles fixed asap too. They can also cause noises that go away when you put the clutch in. From what your describing, that could be the cause of your issue. If your axle fails, you'll be stuck paying for a tow truck. This post has been edited by lagos: Jul 25, 2008 - 5:43 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 25, 2008 - 5:33 PM |
Ok. The axles are getting replaced tuesday, thats the soonest i can get to it.
Say it is the bearing, to replace it, would it be about the same difficulty as replacing a clutch? or is there more to it? Lagos- its a OEM toyota clutch. |
Jul 25, 2008 - 5:44 PM |
About the same as doing a clutch. Gearbox out, take bearing off the fork/lever, new one in, refit box.
Jul 25, 2008 - 5:46 PM |
Dont bother replacing it.
I had the noise, changed mine, had the noise again. The only thing I can think of is that maybe the grease they used (or forgot to use) couldn't stand up to the high temps and isn't doing its job to quiet the bearing a bit. Even if thats the case, it still wont hurt anything. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 25, 2008 - 5:50 PM |
I have the exact same problem, and have been advised exactly the same. Throwout bearing, not worth replacing unless you have to do the whole clutch. It's more just a noise than anything else, and since it's part of the clutch kit, it was/is replaced when the clutch was/is replaced.
Jul 25, 2008 - 7:19 PM |
Thats the thing though, I had the clutch replaced when the tranny burned out on me. I think im going to replace the Axles and see if that helps. If not, well if you guys are saying not to worry about the bearing then kool. when i go in and stage 2 it ill make sure everything is fine and replace if needed.
Thanks guys for all the help. I love this freakin site. |
Jul 25, 2008 - 9:47 PM |
Ok. I got a little more info, i pulled the Invoice that i got when i got my tranny worked on and overhauled.
Complete Bearing Kit Complete Synchronizer kit 5th Speed gear 5th speed Synchro Hub Shift Fork Complete Clutch Assembly My understanding is that if they did a complete clutch kit or Bearing kit then shouldnt they have replaced the Throw out bearing? |
Jul 25, 2008 - 9:52 PM |
Enthusiast Joined Mar 27, '08 From Fort Worth, TX Currently Offline Reputation: 1 (100%) |
I had that happen to me before, incorrect installation was what had happen. The pressure plate might not have been torque evenly and might have spin unevenly causing it to make the rattle with the throw out bearing.
Jul 25, 2008 - 10:09 PM |
Complete Clutch Assembly should consist of
Pressure plate Driven plate Release bearing (Throw out bearing) -------------------- Regards
Aug 7, 2008 - 5:25 PM |
Ok guys Update:
So the tranny place that i sent my car to said tat they felt like it was the Bearings too and they would go in a replace them for me for no charge. I got it back to day and i can still hear this noise. they said they replaced all the bearings and that they couldnt hear it anymore. But i stil can. I also had them replace the Axles for me and now i also have a grinding noise coming from one of the front tires. Sounds like smooth Metal grinding against metal. like if the Rotter was rubbing on something. I think this problem is the rottor rubbing against the Dust plate behind the rottor, not the brakes because it does it wether the brakes are pushed in or not. so im not taking it back to these assholes, Anyways. So lets say that the Bearing was replaced and the tranny checked out and everything was fine. Also the Axles are replaced and are not clicking and are cause NO vibration or shaking of the car at all. That being said. what could make a rattleing sound when the clutch is not depressed at ideal or at coast, but does not make a rattleing sound when the clutch is depressed or in gear driving down the road? Question: When you depress the clutch does it stabalize the engine at all? like Lets say that a motor mount was bad and the engine was rocking more then it should due to this mount being out. If i depress the clutch, does that stablize the engine in the bay? This post has been edited by Havok1997GT: Aug 7, 2008 - 5:54 PM |
Aug 7, 2008 - 8:25 PM |
bump
Aug 8, 2008 - 5:12 PM |
bump anyone?
Lo-Fi Version | Time is now: November 28th, 2024 - 6:38 AM |
