Rattling when clutch is not engaged, STILL NEED HELP GUYS!!!!!!!!!! |
Aug 8, 2008 - 10:33 PM |
If it sounds like a loud rattling coming from the tranny, its more than likely the throw out bearing. Even if you replaced it before, you could have gotten a cheapo one and now its out. If you are able to disengage the clutch and drive normally with the loud noise which gets worse when your in high Rpm's. Very easy to replace but requires you to take off your tranny since its attached to it and not the clutch it self.
Lo-Fi Version | Time is now: November 28th, 2024 - 6:41 AM |
