> How to remove/relocate DRLs
post Jul 25, 2008 - 4:13 PM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
Does anybody know how to remove or relocate DRLs on a Canadian-spec GTS? I'd like to have the front signal markers as my DRLs instead. I tried removing some of the relays in the farthest front relay box (just behind the rad) and it seems to keep some things from working.
Help?
post Jul 26, 2008 - 10:15 AM
GTSOwner
Joined Sep 28, '06
post Jul 26, 2008 - 12:09 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE (GTSOwner @ Jul 25, 2008 - 10:13 PM) *
Help?
Relocating isn't an easy job. You need a good understanding of electricts to pull it off. Disabling DRL is possible. You need to remove both DRL relay #3 and DRL relay #4 and then use two short wires with male spade connectors on both ends. Use one wire to bridge between pin 1 and 2 of the socket for DRL #3 and the other wire to bridge between pin 1 and 2 of the socket for DRL #3.
http://www.celicatech.com/vfewdsou/1995/95...ic/hdlitcan.pdf
You won't want to do this if you are still in Canada though - I'm pretty sure it is illegal in Canada to disable DRL fitted from stock.
post Jul 26, 2008 - 1:33 PM
GTSOwner
Joined Sep 28, '06
QUOTE (BloodyStupidDavey @ Jul 26, 2008 - 12:09 PM) *
Thanks very much for that!
But would you mean bridge 1 and 2 of #3 and 1 and 2 of #4?
I'm not too worried about the legality of what I want to do, because as stated, I plan on "creating" other DRLs either by using the front flashers or my ST202 fogs. Besides, cops here are more worried about how loud your car is or hassling JDM import owners. wink.gif
This post has been edited by GTSOwner: Jul 26, 2008 - 1:34 PM
Lo-Fi Version Time is now: February 22nd, 2025 - 3:29 PM
