> ITS ALIVE!!!!!!!!!!!, nothing beats b00sting
post Sep 14, 2003 - 11:30 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
man o man did i have a good day!!!!
i got the turbo in and solved the oil pressure problem.
all i can say is WOW. at 50% throttle it is faster than the car was when NA at 100% throttle
i had a ton of problems today. the piping kept blowing off at different places and then the gasket i made blew apart(used the wrong gasket material)
but its all working now and im boosting at 6psi with no hesitation and a whole lot of noise. im running only a down pipe that i made myself until i can get one made on tuesday.
so, yeah, after a year of parts gathering, hours of thought, and days and days of work, ITS DONE(well, the parts i can do that is)
BTW, the best part was hearing the BOV, which is really really really loud. i could clearly hear it despite running open exhaust.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 14, 2003 - 11:34 PM
ghostdog
From ny to philly
post Sep 14, 2003 - 11:36 PM
YellowTwo
Joined Jul 25, '03
From Santa Barbara, CA
what exactly is 6psi? and about how long does it take to feel the turbo kicking in?
post Sep 14, 2003 - 11:46 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (6gencelicasrule @ Sep 14, 2003 - 9:36 PM)
at 50% throttle i get a swift kick in the ass 1/2 way through 1st gear.
btw i have an auto tranny.
on one drive, i made a left turn and the tranny shifted while at 6psi and right as second gear hit i ran over a part of the street with a small amount of dirt and lost all traction. the speedo went up and the car slowed down.
btw 6psi is the air pressure created by the turbo. all non turbo engines technically run at around 14.7 psi which is the standard atmospheric pressure. increasing the pressure in the engine drastically increases the power the engine makes.
post Sep 15, 2003 - 12:49 AM
FallenHero
Joined Dec 26, '02
From Alabama
Parts list us, and go get us a Hp figure!
Jon
post Sep 15, 2003 - 1:23 PM
At what RPM is ur turbo kicking in? The 3s kicks in real close to 3K but i prefer that cuz i dont want to be boosting when im driving slowly ya kno?
Also, PSI is pounds per square inch. PSI reading tells you how much air pressure the turbo is forcing into the throttle body. The more & the denser the air, the more/better burn you get. Lamens: The more PSI the more boost, the faster you go. 6PSI is pretty impressive for the 7afe, Congrats.
With the BOV...did you put it towards the throttle body end, or the turbo?
What kind of BOV? and do you have any backfiring issues with it?
post Sep 15, 2003 - 1:41 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Supersprynt @ Sep 15, 2003 - 11:23 AM)
turbo kicks in at about 3000 as well, but only if i give it more that 25-30% throttle, otherwise i can hit redline with no boost.
as for the BOV, i have it on the hot pipe after the intercooler. it is about 1 foot away from from the throttle body
and i dont have and never will have backfiring problems(caused by open atmosphere BOV's) because i have a MAP sensor where you have a MAF sensor.
i got some generic, cheap aluminum BOV off of ebay. it was $50 and it looks good and sounds great.
post Sep 15, 2003 - 2:11 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
So you have an auto? I was interested if putting such things (Turbo, 3SGTE) in an auto tranny (like mine) would be worthwhile. Opinions?
- Ryan
aim: rkgreen04
post Sep 15, 2003 - 2:17 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Akimbo @ Sep 15, 2003 - 12:11 PM)
it would take custom work and a fully programable ECU to make an auto tranny(such as the 5sfe auto tranny or the 3sge auto tranny)
in a straight line, technically an auto tranny equiped car will be faster than a 5spd car with the same setup, just because the guy with the auto tranny never lets off the gas and never has the turbo slow down on him. doesnt mis shift either.
but in the end, its personal preference.
post Sep 15, 2003 - 2:19 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
- Ryan
aim: rkgreen04
post Sep 15, 2003 - 2:23 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Akimbo @ Sep 15, 2003 - 12:19 PM)
yes, yes it does
post Sep 15, 2003 - 7:59 PM
Yeah i was going to put it between the throttle body and intercooler too, but its real tough on the 3s cuz of the TMIC.
Did you weld the BOV or get a kit?
This post has been edited by Supersprynt: Sep 15, 2003 - 7:59 PM
post Sep 15, 2003 - 10:02 PM
FallenHero
Joined Dec 26, '02
From Alabama
What kind of ECU work did you do?
Jon
post Sep 15, 2003 - 11:25 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Supersprynt @ Sep 15, 2003 - 5:59 PM)
a lot of this setup was custom fab.
as for ecu work. i have an SAFC2 that i will use to control the fuel along with the 12:1 vortech fmu.
post Sep 15, 2003 - 11:33 PM
boosted_K2
Joined Aug 30, '02
From Michigan
No but I don't buy it
Cause I'm...
post Sep 15, 2003 - 11:50 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (K2_Celica @ Sep 15, 2003 - 9:33 PM)
nothing quite like boost hitting hu?
post Sep 15, 2003 - 11:58 PM
boosted_K2
Joined Aug 30, '02
From Michigan
the first time it hits you your only reaction is OHHHHHHHHHH ****!!!! hehe yea, nothing like boosting. my mom has a supercharged 04 grand prix GTP, but that just doesnt compare to a lightweight turbo car. mad props on the turbo setup... you need to get some video, and definatly get a dyno on it.
Cause I'm...
post Sep 16, 2003 - 12:05 AM
snadman
From Minnesota, USA
QUOTE (97sccelica @ Sep 15, 2003 - 12:17 PM)
Can't mis-shift...oops I can lol. If you shift with you automatic, unless you go from 1st to 2nd at 4000 revs, in which case it will shift at redline, it may go to fuel cutoff. Sometimes, if I shift too late with mine and have it at WOT just pedal to the metal all the way....it will not shift and I lose. lol.
Now, boost is awesome, but you guys are running like what...160hp to the wheels? Have you guys ever driven a car running like 300 with boost? It's crazy fast...especially when the engine is rotary...mmmmmmm.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Sep 16, 2003 - 12:06 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (K2_Celica @ Sep 15, 2003 - 9:58 PM)
that's exactly what i said. "OHHHH ****"
and let off the gas. it seriously scared the crap outta me. i have driven several turbo cars, but never one that wasnt a factory turbo car. the power just hits so much harder in my car.
i will get some vids right after i pick up the car from the shop, hopefully right after school tomorrow.
as of now i still have the stock exhaust from the cat back to the stock muffler, so it should be quite until i install the DR catback exhaust except for the BOV, it echos off of houses and walls every time it blows off.
i'm working on finding places that will dyno the car for a good price.
post Sep 16, 2003 - 12:36 AM
FallenHero
Joined Dec 26, '02
From Alabama
Parts list...! Also, how many miles do you have?
Jon
Lo-Fi Version Time is now: December 2nd, 2024 - 10:10 PM
