> Door cloth, falling off..
post Jul 28, 2008 - 3:23 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
Should i rip it off or try to stick it back on? there's some glue residue under the cloth that looks like water marks so i'm trying to make it go back on. is there a technique to tucking the cloth under the elliptical pad it sits on?
post Jul 28, 2008 - 3:33 PM
DEATH
Joined Dec 19, '07
From tx
I used a thin 6" scale to tuck it back in the creases around the edge. I stuck it to the pad first then dabbed a little super glue [the gel kind works best so it doesn't make hard spots] into the edges and used the 6" scale to tuck it in. Looks perfect after you're done just be careful to go really easy on the glue so it doesn't squeeze out.
Good luck
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jul 28, 2008 - 3:35 PM
ETNRIDER
Joined Feb 10, '06
From Knoxville, TN
Pics of this would be great, I am thinking about adding the cloth to mine.
post Jul 28, 2008 - 3:45 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
The cloth that comes on the door IMO is gross. It feels icky and looks highly flammable. I say either replace the cloth with something nicer (the route I'm going, personally) or get rid of the cloth all together. You could paint the oval part a different color for that two-tone effect if you were so inclined, even.
post Jul 28, 2008 - 3:54 PM
DEATH
Joined Dec 19, '07
From tx
I'm going back over my stock leather inserts with velvet I think.
Griffy - you should have seen them when the car was new - it looked really good. However it has soaked up skin particles from all the owners and years of contact so it is nasty now. Same with the headrests.
EXT: WRC/TRD/404
post Jul 28, 2008 - 11:16 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
QUOTE (DEATH @ Jul 28, 2008 - 4:54 PM) *
it is a pretty nasty fabric i agree (like a blue/grey draylon sofa) and the skin particles just did it for me, it has to go biggrin.gif
post Jul 29, 2008 - 3:16 AM
parriehunter
Joined Jan 13, '08
From Christchurch New Zealand
I used F2 glue to put it back on when my drivers side come off, the passengers side is now coming off im thinking of using some vinyl and putting that on instead of the cloth.
my drivers side has stuck on well.
post Jul 30, 2008 - 2:59 AM
blackbullet
Joined Jul 21, '04
From Fresno, CA
I used some 3M glue spray can that they sell in the automotive section like at WalMart. They are for cloths and other things in your car. Sprayed mines and it stuck on pretty good. Also sprayed the top roof my girlfriends corolla because the top cloth was peeling off and it stuck on pretty well.
post Aug 4, 2008 - 1:01 PM
Lexicon_Devil
Joined Aug 22, '07
From Downriver, Michigan
Yep. I used Spray Tack on mine and it worked great. I'd stay away
from the super glue. If you needed to take them off, you could use
a heat gun or even possibly a blow dryer to loosen up the spray tack.
If you use Super Glue, you may run into a serious clean up project
down the road if you need to take them off.
My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
94 Celica GT
89 Sentra Sport Coupe Project (the other haggard woman)
post Aug 5, 2008 - 2:10 PM
GriffGirl
Joined Feb 7, '07
Spray adhesive is DEFINITELY the way to go with this. It'll hold quite well but still allow removal of the fabric if necessary. Don't forget, when you spray it, to let the spray set for a few seconds before applying the fabric. For best results, spray both surfaces with the adhesive.
post Aug 7, 2008 - 5:47 PM
need to see pics....
post Aug 7, 2008 - 6:41 PM
gt_driFFter
Joined Nov 29, '04
Dude, rip it off! One of mine were peeling off so I yanked it. After a lot of elbow grease (getting the old glue off), it's the same exact material as the dashboard! Looks great!
post Aug 7, 2008 - 9:43 PM
Lexicon_Devil
Joined Aug 22, '07
Griffgirl,
Right on with the spray advice. That's exactly what you need to do.
And use a putty knife or something similar (not sharp) to push the
fabric into the creases.
Gt Driffter,
Along with yer elbow grease, what did you use to get the glue off?
Goo Gone? Fast Orange? Something similar?
94 Celica GT
post Aug 11, 2008 - 12:33 AM
gt_driFFter
Joined Nov 29, '04
Goo Gone! It looks real good, I'll try to get pics of it soon!
post Aug 11, 2008 - 1:02 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
do they sell that in the uk or will wd-40 do?
post Aug 11, 2008 - 1:49 PM
frisp
Joined Jan 2, '08
From Scotland
available in the UK Here
Regards
frisp
HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier
Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's
JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6
To be done....
Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads
post Aug 11, 2008 - 1:56 PM
GriffGirl
Joined Feb 7, '07
Oh don't use WD-40, I think you'll just have a greasy sticky gluey mess on your hands! Goo-gone or the likes thereof are definitely the way to go. Luckily most of the adhesive is so dang crusty, it'll actually come off with a dry cloth. Mine did; in fact, there was hardly any adhesive to even have to bother with.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:53 AM
