> aem wideband?, question
post Jul 28, 2008 - 10:20 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
hey guys, quick question. somebody is sellin their wideband o2 sensor, (AEM UEGO) for 200$ im boosting my 7afe and will probably look into getting one. my two questions are... is it necessary? and secondly, does it work with a gauge other than the AEM gauge that comes with it? i have a 3 gauge pillar and my AFR matches the rest, and want to use it. will it work with my AFR gauge i currently have?
thanks guys.
and quick feedback would be awesome! im supposed to buy it tomorrow morning! thanks
allen
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
post Jul 28, 2008 - 10:40 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
the sensor itself will work with just about any wideband display.
yes, you need one.
post Jul 28, 2008 - 10:45 PM
it's nessessary.
but I'm not sure a generic afr gauge is designed to work with a wideband sensor/controller.
post Jul 28, 2008 - 10:52 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
ive got the AFR from prosportgauges. it says it will work with any wideband with an output of 0-5v but bosch isnt compatible. one of the AEM ones are a bosch replacement. hopefully ill get lucky? lol
1991 Toyota MR2
MySpace
post Jul 28, 2008 - 11:23 PM
the AEM UEGO uses a bosch sensor.
post Jul 28, 2008 - 11:54 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
*NEW FEATURE*
This gauge can be set to read narrow band or wideband (0-5v) with the flick of a switch in the back of the gauge. That means that you can now use this gauge with your stock narrow band O2 sensor or use it with a control unit like innovate to display a 0-5v signal.
NOTE: This cannot be used as a stand along wideband AFR with a bosch wideband 5 wire heated O2 sensor unless you are using a controller! (Our complete wideband AFR gauge is due out end of June)
thats the notice it gives me for the gauge i bought. batman, since you know more about the AEM sensor. is it compatible with working with this gauge i have?
1991 Toyota MR2
MySpace
Lo-Fi Version Time is now: December 4th, 2024 - 9:00 AM
