> Turbo fittings, What size?
post Sep 15, 2003 - 12:16 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Ok I need to see if anyone knows the sive of the fittings i need
I need 3 T fitting i was told to put on the the MAP senor vacum line so it will see atmosphere so it will run right. Size?
Ok I need a Y for the Block for the oil line. Size?
I need a Y for the collant line Size?
99 Toyota Tacoma
post Sep 16, 2003 - 1:43 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (JWalk1818 @ Sep 15, 2003 - 10:16 AM)
1. The MAP is a replacement. In with the new out with the old. Look top left of your fire wall, above and to the right of your wire harness is the map.
2. take the oil pressure sensor off and and go to NAPA and get a T fitting for it. 1 male side and 2 female. You will not leak oil when removed just dont start the car.
3. You dont need a Y for the coolent. Get 2 hose adapters and some hose of equal size.
-Bryan-
Member of Team 5sfTe
Lo-Fi Version Time is now: January 17th, 2025 - 6:38 PM
