rusty door bottoms..., ..and how to stop it-suggestions please? |
Jul 31, 2008 - 11:35 AM |
Enthusiast Joined Jul 2, '08 From Midlands, UK Currently Offline Reputation: 0 (0%) |
As you may or may not know the doors on 6gens have a drainage hole at the bottom which is a really bad idea as water collects in the bottom door seam and causes the dreaded rust. Mine have a small amount on the surface and I would like to know how to stop it getting any worse. Is it safe to block the hole up or will that cause serious damage?
Any ideas for members will be much appreciated, thanks |
Jul 31, 2008 - 11:41 AM |
Enthusiast Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) |
The rust normally gets hold because the drains get blocked. Both my doors have the dreaded tin worm. If it's not too bad, sand/grind as much off as you can. Treat with a good rust treatment/convertor & repaint. You could use waxoil or similar after treating/painting too. Just make sure the drain holes stay clear.
Going have to change both my doors, will be stripping to bare metal and painting with POR-15 before paint/waxoil. Hope that helps. -------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Jul 31, 2008 - 11:49 AM |
Hi, and thanks for the suggestions. Luckily the car was only imported 5 years ago so isn't too bad
I was wondering wether to fill the seam with filler so the water doesn't collect in there as well? good idea? This post has been edited by hardcoreproducer: Jul 31, 2008 - 11:52 AM |
Jul 31, 2008 - 11:50 AM |
Only a good idea if you are sure there in no rust in the seams already. though, it will slow it down a bit if it's already present.
Jul 31, 2008 - 9:51 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 5:55 PM |
