> Camry Tranny?
post Jul 31, 2008 - 12:45 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
So i found a 99 Camry solora tranny for a good deal, i was just asking if it would work with my 3s swap, now i believe its a e153 tranny right? so it should bolt right on the the 3s, also i would use the camry inners and the set of outers that i have on my car as well, is there a advantage with the camry solora tranny, like gearing, lsd?
post Jul 31, 2008 - 5:12 PM
gearing, durability, yes.
you would need MR2 turbo inners and all-trac outers, and at least a 1/2" spacer for the pass side axle.
As for mounts...st205 rear w/bracket, st205 driver's side w/bracket, and you can use your GT/ST front mount/bracket.
edit, and the st205 shifter cables.
This post has been edited by Batman722: Jul 31, 2008 - 5:12 PM
post Jul 31, 2008 - 5:20 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
i have all those right now for my mr2 tranny, but i was just making sure that its gonna be plug and play
post Jul 31, 2008 - 9:47 PM
I didn't know you had the mr2 tranny, yes it should be plug and play.
post Aug 1, 2008 - 12:01 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
kk thanks, btw i can still use the same clutch right
post Aug 1, 2008 - 8:50 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE (supra12big @ Aug 1, 2008 - 1:01 AM) *
i say yes dont have time to double check, will look into later
This post has been edited by devilsden97: Aug 1, 2008 - 8:57 AM
Kawi Love
post Aug 4, 2008 - 8:08 PM
phattyduck
Joined Dec 5, '05
From LA, CA
You probably already know this... but make sure it is a V6 Solara trans, not the 4-cyl trans... wink.gif
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Aug 5, 2008 - 7:07 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
it came off a 3.0 solora,
post Aug 5, 2008 - 8:42 PM
what about the gear ratios on this tranny, is it the same as the s54 , you know high revs on 5th gear while doing 70?
can i use it on the 5s?
This post has been edited by njccmd2002: Aug 5, 2008 - 8:45 PM
post Aug 7, 2008 - 12:54 PM
devilsden97
Joined Jun 13, '05
QUOTE (njccmd2002 @ Aug 5, 2008 - 9:42 PM) *
way to jack the mans thread.. lol jk
To be totally honest, if u guys have specific questions, a good person to ask is Silver94celicaowner. He did a 3rd gen swap in his car, with an e513 (non-lsd) tranny out of a Camry. He should know a fair amount about its capabilities, and its compatabilities.
.....If hes ever on.
Kawi Love
post Aug 8, 2008 - 5:37 PM
QUOTE (devilsden97 @ Aug 7, 2008 - 1:54 PM) *
hey laugh.gif , not jacking he needs to post more info on this, seems like a good trade, i hate my tranny.... But i will see Silver94celicaowner, thanks,,,
Lo-Fi Version Time is now: November 24th, 2024 - 10:44 AM
