> exhaust temp
post Aug 4, 2008 - 9:15 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
just wondering what the exhaust temp should roughly be on my 3sgte. performance parts include 3" turbo back exhaust, rebuilt ct26 with larger compressor wheel, blaster 2 coil, nology hotwires and nology silver spark plugs D4YS, and a front mount intercooler. i have an exhaust temp sensor set into the stock exhaust manifold for the 4th cylinder since it was the closest to the motor. just wondering so i will be able to tell if my engine is running rich or lean due to higher or lower exhaust temps.
This post has been edited by 6G94celica: Aug 4, 2008 - 9:17 PM
post Aug 6, 2008 - 8:48 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
you should see 900-1000F at hot idle
you should see 1350-1400F when cruising
you should see 1300-1350F when boosting
you should never see more than 1500-1600F
Lo-Fi Version Time is now: November 25th, 2024 - 10:45 AM
