st202 and st204, difrences |
Aug 6, 2008 - 1:33 AM |
Enthusiast Joined Nov 13, '06 From AUSTRALIA(MELB) Currently Offline Reputation: 0 (0%) |
whats the difference between the two?
can you fit the st202 motor in the 204 chassis? can the 202 engine bolt onto the 204 gearbox? what modifications need? |
Aug 6, 2008 - 5:29 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
ST202 carries 3SGE engine (or beams for the 4th gen), you can fit a 202 motor in the 204 no problem, the 202 tranny should work just fine. The only mod I can think of is the wiring.
-------------------- 98% completion --- aaRon |
Aug 6, 2008 - 5:45 AM |
Enthusiast Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) |
ST202 carries 3SGE engine (or beams for the 4th gen), you can fit a 202 motor in the 204 no problem, the 202 tranny should work just fine. The only mod I can think of is the wiring. more than likely need the harness and ecu to complete the swop easily -------------------- |
Aug 6, 2008 - 4:01 PM |
nice.... how much power does the 202 have more making?
Aug 8, 2008 - 12:13 AM |
bump
Aug 8, 2008 - 12:29 AM |
Enthusiast Joined Aug 7, '08 From Boone, N.C. Currently Offline Reputation: 0 (0%) |
Both models are "s" series engines. So the tranny and moter mounts, even the clutch would work perfectly. But the st204 comes with a 5sfe engine. Wich is a fuel economy engine which means it doesn't have the vvt-i. So wiring and ecu will not work. But phoenixtuning.com will provide you with a plug and play wiring harness.
This post has been edited by celica_122: Aug 8, 2008 - 1:25 AM |
Aug 8, 2008 - 6:11 AM |
wouldn't the 202 ecu and wire hardness come with the engine if i buy a halfcut..? if i do buy it, is it just straight plug in... like cluster.. and engine bolts right in.. is there any other modifications required anywhere... like will my power steering work with the 3sge engine? ect...
Aug 10, 2008 - 2:16 PM |
Since the power steering pumps, a/c compressor, alternater, etc. are mounted in the exact same location and the engine blocks are almost exact. It should work just fine.
Aug 11, 2008 - 7:44 AM |
nice..... so i can just drop in the 3sge beam engine... plug up the ecu and wire loom and it will start up? do i need to get the 202 cluster.... is it hard to put in the cluster?
Aug 11, 2008 - 8:11 AM |
nice..... so i can just drop in the 3sge beam engine... plug up the ecu and wire loom and it will start up? do i need to get the 202 cluster.... is it hard to put in the cluster? As I said before you need to do some rewiring and you might need the 202 cluster for the odo to work. -------------------- 98% completion --- aaRon |
Aug 11, 2008 - 2:21 PM |
I agree. If you use the 3sge wiring harness it will follow the correct path... but not so sure it will just "plug up." It probably would with the correct cluster and the 3sge ecu. And if not it wouldn't be hard to correct. As long as you have wiring diagrams for both engines to cross reference. But there realy isn't a lot of differences between the 2 engine designs.
May 31, 2010 - 5:16 AM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
Sorry bout the old thread bump, but just wondering if there is much or any difference in the suspension between the two.
I'm looking to buy a set of BC Coilovers, although, the Vehicle Compatibility says Toyota Celica ST202 (94-99). My car is the Australian ST204 Liftback. http://justjap.com/store/product.php?produ...at=0&page=1 Would these still fit and work perfectly? Thanks. -------------------- |
May 31, 2010 - 8:26 AM |
Provided that you don't have a SuperStrut Suspension setup, it'll work just fine.
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 24th, 2024 - 3:34 AM |
